help, my trailer is stuck and wont reverse.
  • archcityblues
    • Aug 2013
    • 142
    • canada
    2014 trailer, solinoid (sp) blew, just had it fixed under warranty and its done again. happened as i was backing up the curb of my driveway, some fluid leaking out about half way between the tongue joint and the ball socket. any idea why this might be happening? my neighbour who is away as we speak, put tape around something last year so i could reverse. any ideas how i can back it up for the time being? thanks very much
  • Laketexoma
    • Dec 2004
    • 463
    • Lake Texoma (Texas side)
    • 2023 G23
    In a pinch you can always put a socket in the sliding part. Just a have someone hold it there for a second while you backup. The pressure will hold it for the rest of the time. Now when you go forward it will fall
    2016 G23 H6
    2014 G23 550
    2013 G23 450 (Great boat)
    2000 SAN ( Loved that boat)
    • scottb7
      • Aug 2011
      • 2198
      • Carson City, Nevada
      You need one or two of these with trailer at all times...
      http://www.trailertugpro.com/product...roducts_id=272
      • cedarcreek216
        • Oct 2009
        • 1009
        • Dallas, TX
        • 2018 210 2013 210 2009 216V
        That's a great addition to the on boat tool box, never thought about need one but makes sense.
        • Calpunk1
          • May 2013
          • 17
          • Southeast
          • 2014 SAN 230
          I used to use one of these with my other trailer all the time. Just keep a roll of electrical tape also. When you're by yourself just pop it in and tape it into place and you can reverse the trailer without problems. Not sure why it's leaking but sounds like in got pinched potentially if you have a swing away tongue?
          • HS
            • Oct 2007
            • 1333
            • Sammamish, WA
            • 2010 SANTE 210 (Sold)
            need to find the source of the fluid leak -- I think there is a hydraulic piston that drives the booster brakes, so that could be a separate issue from the reverse lock-out solenoid.
