Also put a little more weight in the bow so you will get a longer wave and the trough won't be so steep and feel like you are dropping off a bump. Nice ride man!! looks like N3 boatworks?
So I got the u sac plumed in. Put 750 in driver corner and then stuck both 400s in the other, I figure with driver weight and prop rotation,the extra 50 over there is good, gna take it out seen and see how it is!! I think it will be good, I surfed the other day stock prob ballast with 750 on then back walkway, the push and wave was huge!!!!
Originally posted by Garrett Burke View PostSo I got the u sac plumed in. Put 750 in driver corner and then stuck both 400s in the other
How did you plumb the extra 400 sac...top sac drain to bottom sac fill? Any issues with both sacs in there...either filling, draining, or moving around?
Thanks!
Thanks!
