Swim platform rattles 2012 SANTE 210
  • agouge888
    • May 2012
    • 102
    • Tennessee
    • none
    I have a 2012 SANTE 210 and while idling slowly or in neutral...the exhaust turbulence rattles the platform. I was just noticing on a friends 2014 230 that it has the same rattle caused by the bubbles and air from the exhaust. His 2013 did it too. Anyone else had this problem? Any good ways to buffer it?
    thanks,
    agouge
  • eff1fitty
    • May 2012
    • 112
    • Tennessee
    • 2011 230 SANTE
    I have a 2011 230 and can't say I have heard any of this rattle. There is a little play in the platform when I am on the rear of the boat and waves crash into it, but nothing more. I will be interested to hear if anyone else is dealing with this.
    2011 230 Super Air Nautique
    • SkiTower
      • 2172
      • Clayton, NC
      is the platform the hinge type? I believe there are two diff styles during these years
      2007 SV211 SE
      2007 SV211 SE
      Tow Vehicle 2019 Tundra
      Dealer: www.Whitelake.com
      • 4th ski-doo
        • Apr 2013
        • 307
        • Wilmington
        • 2013 SANTE210 2011 Sport200V 1994 Bimini Skier 190 1986 Master Craft Pro Star 190
        Mine does, so did my 11 sport
        2013 SANTE 210
        2011 Sport 200 V
        1994 Bimini Skier Pro 190
        • BIGAIRCPA
          • Sep 2012
          • 64
          • Illinois
          My 2012 230 does it minimally...
          • Nautiquehunter
            • Jun 2008
            • 2080
            My 08 210 does it only at low speed. As soon as the speed is a little higher the exhaust will stream back away from the platform.
            • agouge888
              • May 2012
              • 102
              • Tennessee
              • none
              2007 SV211 SE
              Mine me just slips in the brackets and a pin holds it in place on each side. I usually keep a couple hundreds lbs of lead/ weight in each rear locker so it so it does sit the platform a little lower than stock, even when I don't have the tanks full. Still does it with ballast or without.
              agouge
              • Dinsdale
                • Aug 2010
                • 60
                • British Columbia, Canada
                • 2019 G23
                My Sport 200 rattled like crazy. Drove me crazy. I took the platform off and put one piece of electricians tape on both the boat bracket and the platform bracket. Put it back together and not a sound!
                2012 Sport Nautique
                2011 Sport Nautique (Sold)
                2000 Malibu Sunsetter LXI (Sold)
                • scottb7
                  • Aug 2011
                  • 2198
                  • Carson City, Nevada
                  i have a 2008 210, never noticed this issue.
                  • lucky7t
                    • Mar 2011
                    • 1306
                    • Oklahoma
                    • 2015 SANTE
                    My 12 210 does the same thing. It actually sounds like a slapping noise while surfing. Dealer says that's normal
                    Current Correct Craft Boat
                    Correct Craft Boats Owned
                    • ronskal
                      • Jun 2010
                      • 58
                      • San Angelo, Texas
                      • 2010 SAN 210TE
                      Have not noticed it on a 2010 210 but now I probably will and be all psycho about it.
                      I do remove my platform every now and then and grease the 3 vertical mounts real good, try that?
                      sigpic
                      2010 SAN 210TE
                      2004 Mastercraft X2 (Sold)
                      2005 Sea Ray 210 Select (Sold)
                      • perry386
                        • Jun 2012
                        • 560
                        • gadsden AL
                        • Super Air nautique 236
                        Instead of using the factory pins find a bolt and nut that is a little bit thicker and use that. It will make it a tighter fit and not allow it to move so much.
                        • pzthk6
                          • Mar 2008
                          • 68
                          • St Cloud, FL
                          • 2014 SAN 210 2007 SANTE 220 1989 Centurion Barefoot Warrior Comp 1991 Concept 21' CC
                          Common problem with removable platforms. If you do not need to remove yours often, remove the pins, ream out the holes to 5/16" or next common bolt size larger, then bolt it in place. If there is still a slight rattle, remove the platform, place some pieces of the soft side of Velcro on the top interlocking hooks, reinstall and bolt in place.
                          Unfortunately, the platforms have to be made loose enough to easily remove, but when the boat is weighted the platform acts like an upside down bucket in the water and catches all the exhaust bubbles.
                          • CradGen2
                            • Aug 2020
                            • 1343
                            • Horseheads NY
                            Mine does it too. I just live with it. I like the brackets vs the old ones, I'll live with it.
