Blown Exhaust Gasket
  • bubba
    • Jan 2010
    • 79
    • Minnesota, USA
    • Current: 2008 Ski Nautique 206 Previous: 1984 Ski Nuatique 2001 Long time ago: Glastron/Carlson DV16, 115 Johnson
    Happy 4th to all... After skiing this morning on the way back to the dock the starboard side exhaust gasket blew. Will running the boat with a blown exhaust gasket cause any damage? The motor is a 2008 343 Excalibur.
  • eff1fitty
    • May 2012
    • 112
    • Tennessee
    • 2011 230 SANTE
    Yes, it will be ok to run. Probably will drive you crazy with the ticking from the exhaust leaking out. You will want to get it replaced soon to prevent warping the manifold.
    2011 230 Super Air Nautique
    • scottb7
      • Aug 2011
      • 2198
      • Carson City, Nevada
      Pretty easy to replace, it just is a bit noisy as stated above.
      • Nordicron
        • Sep 2009
        • 557
        • Madison, WI
        Yeah put your order in to white lake and do it yourself. You'll want the riser gasket too. I did both sides of mine. Check the torque after an hr run time then again at 20
