I didn't order the factory camera so I'm wondering has anyone done anything after market with a back up cam or similar with great results? The gopro just seems too wide and I'd like to have it plugged into the open camera port in the LINC system. It would come in real handy when I'm getting up a surfer since they are so close to the boat to start with. TIA!
Tags: None
I had my dealer install the vio pov system that you can order from the factory. Advantages: easy to use, hand held small remote, fits unobstructively on boat, great quality of pic and easy to use. Disadvantages: not cheap, date and time need to be reset with each power on/off, not vertically aimable so if pulling beginners at slow speeds (<18mph) will not put the rider at the center of action.
Here is a link from another forum (Tige) with information on hooking up a Go Pro through there display instead of using the factory tower camera. Depending on the input to the LINK display this could potentially be very similar.
http://www.tigeowners.com/forum/show...-on-Tige-touch
For surfing this may be a much better option (or something similar) thank the tower camera. Good Luck!
