I am a first time owner and want to do a ballast install in the future, but for now with a few friends, where would a 500 -750lb. fat sac be the best placed for wakeboarding?
If you are buying sacs new then I would recommend you get 2 750s and the 580 lb rear seat/locker sack from Fly High because it fits almost perfect in the in-floor ski locker. That way when you go to integrate your ballast you already have the sacs you need. If budget only allows for two sacs then I would recommend the 2 750s to start with. With one sac full as far back in the main lounge as possible and the other full sideways in bow back near the windshield. If you are set on only one sac for now then a 750 in the middle of the lounge as far forward as you can get it or the 580 in the ski locker. The beauty of the 3 sacs is that you can have all that ballast hidden with the 750s in the rear lockers and 580 in the floor ski locker. You probably won't want to fill both 750s full in the rear unless you have additional weight in the bow to counteract it and help you to get on plane. The u shaped under seat sac works great for additional bow weight when you need it. Although I am not sure if that u shaped sac works with the playpen bow that you have because my boat was the walk through bow.Shawn
2012 Blue Metal Flake SAN 230
