How much should I pay for 2000 Super Air Nautique?
  • bdsmith1
    • Aug 2014
    • 7
    • Orlando
    • 2000 SAN
ID:	382072Click image for larger version
ID:	382073Click image for larger version
ID:	382074Click image for larger version
ID:	382075Click image for larger version
ID:	382076Click image for larger version
ID:	382077I have been searching a few months for a SAN. I have located a 2000 SAN. This boat is in fair condition for its age. The interior has some cracks in the vinyl, and would need replacing at some point. There are service records available. I test drove the boat, and it starts up great. The boat runs great. It still has the original Teleflex gauges, which are pretty much shot. You can barely see the number "8" on the hours, which tells me there are around 800 hours on the GT-40. But I would obviously need new gauges. There is no perfect pass, something else I would want to add. The right keypad(which controls the ballast function, bilge, lights, etc.) is not working, the seller said that he had the whole right side simply disconnected. I don't know how hard this would be to re-wire and correct.
    The seller is asking $15,000. What do you guys think of this price?
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    I think it is great (low) price, assuming there is nothing else major wrong. I wouldn't sell my 2000 San for anywhere near that low. I am assuming it comes witg the trailer.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • bdsmith1
      • Aug 2014
      • 7
      • Orlando
      • 2000 SAN
      There is nothing else major wrong. I had the nautique dealer inspect it for me. The engine was good, good compression test. Only problems the dealer said was the dash gauges. I just didn't want to drop $15,000 without hearing from some of you guys.
      • Tjca77
        • Aug 2013
        • 58
        • Atlanta
        • 2000 Air Nautique
        The starboard keypad will run you @ 400.00. To my knowledge no one has fixed one of these in the past.
        • Brichter14
          • Jun 2013
          • 531
          • Central Illinois
          Galvanized trailer most likely means salt water use. With it in that terrible of interior shape i would be worried about how well the engine and electrical are maintained. I would offer 12k and not pay more than 14.
          • thedude
            • Apr 2007
            • 451
            • SW PA
            Yeah I'd pass on that one, unless you are looking for a project and have a lot of spare time. I'd guess you are looking at $5k just to get it looking decent (new interior, gauges, keypad, buff job etc). Spend a few more bucks and get something that will be less hassle. Just one guy's opinion.
            • a0128
              • Jan 2014
              • 423
              • Lake Oswego, OR US
              • 1999 Pro Air Nautique
              I'd pass on this one. Too much work. If the interior looks like that I doubt the mechanicals are in any better shape regardless of what the dealer says. Clearly no pride of ownership, which for me is a big deal. I agree with "thedude" you would be looking at $5k (maybe more) to get that in decent shape.
              • Chexi
                • Apr 2025
                • 2119
                • Austin
                • 2000 SAN
                When I first responded, I was on my phone and did not have time to look at the pics. The interior is a bit rougher than I expected.
                If you get PP, you don't need to change the gauges. I did on mine, but you get both speed and rpm on perfect pass. I also wouldn't bother changing the whole interior (which will cost you $5k to have done with factory skins, about half without factory skins). I've done the install myself (with factory skins), and (a) it took me all summer and (b) it makes one too anal afterward. You will have more fun with an interior that you are not always worried about. I would probably change the skin on the observer's seat bottom. That would probably run $150 - $300 depending on who does the installation.
                I think the instrument keypads are connected by Deutsch plugs and are very easy to swap out. They are not cheap though for certain. Remember the PN discount though.
                I would say a 2000 SAN in good (but not pristine) shape on a good trailer should be worth at least 20k (I wouldn't sell mine for less than that, and probably more as I have custom ballast added). The one you are looking at you can still read the hours on. Most have had their gauges replaced, so you would have no idea on the hours for most 2000-2001 model years with the GT-40s. Knowledge of the hours is worth something, and 800 something is about right for a boat of that vintage.
                The real question is whether the boat was a salty. If so, all bets are off on price.
                Also, I would discount it for being that color green. Black, red, blue are you major colors for resale value. Next is probably all white. Yellows, greens, burgundies, purpoles, teals, and other colors tend to be more nichey and have a smaller market for resale, typically resulting in a lower price.
                Now
                2000 SAN
                Previously
                1999 Air Nautique
                1996 Tige Pre-2000
                • bdsmith1
                  • Aug 2014
                  • 7
                  • Orlando
                  • 2000 SAN
                  The owner swears no salt water. There are no signs of corrosion anywhere on the boat or engine.And he says the keypad works, it has just been disconnected for some reason.The nautique dealer said the engine was in good condition with a good compression test.
                  • Brichter14
                    • Jun 2013
                    • 531
                    • Central Illinois
                    You can talk yourself into something all day. Im sure it will work fine and all but that boat is not worth 15. The tan gel and green does not appeal to many. The interior is trashed and its on a single axle galv trailer. Offer him a firm 12 and walk if he comes back higher than 14. My boats white red and black an a 97 that was in prestine shape. Also had perfect pass and 650 hours. Got it for 18500. A deal but nothing unheard of. Keep looking an dont settle. This is an important purchase
                    • DLafont
                      • May 2009
                      • 340
                      • Gatineau Qc
                      Obviously the interior is shot, and needs a whole lotta work. If the dealer "signed off" on the engine and hull, then at 12k you'd be getting this boat at a good price. FYI, book value for mine is still at $20k CDN.
                      Previous: 1990 Ski Nautique
                      • kend
                        • Oct 2013
                        • 193
                        • DFW, Texas
                        • current 2001 Air Nautique previous 1988 Sanger DX
                        minus $500 for the 'not beer' sign on the driver cup holder
                        minus $500 for the wooden rack speakers
                        Ken
                        2001 DD Air GT40
                        • bdsmith1
                          • Aug 2014
                          • 7
                          • Orlando
                          • 2000 SAN
                          The seller said he would take $13,000 and no less.
                          What do you guys think now?
                          • a0128
                            • Jan 2014
                            • 423
                            Say you pay $13k. The boat will most likely need $5k of work to get it into something you would be proud to take friends out on. What else is available for $18K? I'd bet you would be able to find a SS or maybe a SAN in much better condition than what you are looking at. Perfect Pass alone is going to cost you $1200 so the $5k "reconditioning" budget will go fast. I'd keep looking. Even what appears straight forward (i.e. the disconnected dash pad) has trouble written all over it. Who disconnects something that controls some of the most important functions for the boat (bilge pump, blower) and doesn't fix it ASAP? Most likely a short which can be time consuming and expensive to fix.
                            • bdsmith1
                              • Aug 2014
                              • 7
                              • Orlando
                              • 2000 SAN
                              I honestly don't have $18,000 cash to drop on a boat right now. I personally am okay with the interior not being in good condition. I am an avid wakeboarder, and am honestly just wanting something to take out on the weekends to work on my skills.
                              Do you think that I should try finding another boat for around $13,000 or purchase this one for $13,000?
                              Thanks again guys, I appreciate all of your input.
