Pulling a 180 lb skier through the course last week and heard a loud pop as skier rounded ball and pulling to the wake. Glanced at the pylon and it had a significant lean towards back of the boat. Broken pylon sleeve in attached pic shows where the weld busted loose; the actual pylon still securely in sleeve. The sleeve was only welded between the two inserts that connected into the aluminum face. Contacted dealer for warranty replacement; Nautique sent next day air to my dock so very little downtime. I received great service from both dealer and Nautique; however, I was extremely disappointed that the weld could break on the pylon sleeve. The replacement sleeve was welded across the entire face surface; wonder if they have had this issue before and now reinforce their pylon sleeves.
Man....I knew that would happen... Mine came from the factory with the pylon leaning significantly to SB. Had to do with mis-aligned holes in the structure. Decided to fix it myself and when I was in there, I noticed the same thing (sub-standard weld at that joint) so I machined an extra bolt hole through the pylon / sleeve so we could use the boom. Haven't had a problem...yet.Peace..
My intention was actually not so much in beefing up that joint...rather, to make the pylon more robust in the receptacle because I didn't trust the nylon foot / lock pin for forces that can be applied rotationally and vertically (for a boom). So I just added a pin hole to go through the sleeve and the receptacle that locks the pylon in place using a 5/8 x 4 SS pull pin. In my case, I didn't fix the weld, but adds another fastener to hold pylon to sleeve...so still susceptible to the same failure as you experienced.Peace..
Peace..
