Originally posted by nukemustang
View Post
Originally posted by brock.higdon View PostTurns out, the muffler is leaking water out of it. Someone has already done a janky fiberglass repair on it.
That being said,
1. Whats the cost to replace? Where to order?
2. Is it possible to delete the muffler all together, and put a straight piece of pipe in there? Any how to on that?
You could definitely eliminate the muffler as well using stainless or copper & wire reinforced hose, neither of which would be cheaper but would certainly make things a bit louder, or in some persons opinions, better.
I second the idea of having it repaired properly. Had it done by my mechanic last year, didn't cot much and worked great all summers. Unless it is so out of sorts that it can't be repaired.Current : 2000 Pro Air Nautique, Silver&Black accents, pulled by 2012 black Chevy Tahoe
Previous: 1990 Ski Nautique
Quick question. Right above the swim platform, there is a stainless steel water hose connection. Can I run the engine out of the water with that or is it just for flushing?
Originally posted by brock.higdon View PostQuick question. Right above the swim platform, there is a stainless steel water hose connection. Can I run the engine out of the water with that or is it just for flushing?
The hose connection is for flushing out the motor which only works with the engine running. The typical water flow GPM of a garden house will not keep up with the draw from the RWP under higher RPM's, so sustained high RPM's can collapse the garden hose possibly starving the impellor of enough water. Little throttle bursts are fine just don't hold it for more then a few seconds.
$600 for a muffler, you say?
No says I.
http://youtu.be/F3Dan9Hv1eI
It doesn't seem any louder than it was before, which is good. Nice deep rumble.
Next question. Their is a strainer in front of the motor. There is no kind of rubber seal on it and leaking where it threads on. Probably lost by previous owner. Anywhere to order just the seal? If not, where to get a replacement strainer?
edit. Found it.
http://www.nautiqueparts.com/waterstrainergasket.aspx
Next issue. What kind of magic to I need to say to get these hard tanks out. Every way I turn it, it won't come out.
Originally posted by brock.higdon View PostNext issue. What kind of magic to I need to say to get these hard tanks out. Every way I turn it, it won't come out.
Originally posted by brock.higdon View Post$600 for a muffler, you say?
No says I.
Originally posted by a0128 View PostLove to hear that at WOT. How temp resistant is that PVC pipe? Will it stand up to the exhaust temps?
Congrats on the boat, what a story getting her home.
Is it just an illusion in the video or is your exhaust missing the flapper? If it is missing I would get that replaced ASAP.
http://www.nautiqueparts.com/exhaustflappers.aspxShawn
2012 Blue Metal Flake SAN 230
Originally posted by s_kelley2000 View PostCongrats on the boat, what a story getting her home.
I just had not put it back on yet. Thanks, though.
