The standard steering kit comes as a taper shaft. A non tilt, splined helm would be
required, and I am not sure they come that way.
You can add tilt to the system but it requires the tilt mechanism, and the part that the cable mounts to. Then there is a little universal joint doo dad that makes it all happen... If I can dig up a non tilt helm with splines part number, I'll pass it on.
