Originally posted by vasco
I just put the 536 on my 97 ss with the GT-40. The prop is nice and smooth. I replaced a OJ 14x18. The hole shot with the 536 is better, the rpms are around 150rpm faster at the speed I ride. Boat is setup with 2300lbs of ballast plus people and I ride around 24.5mph. The rpm's are 3150 with the 536.
I am not sure why the 644 would be a better prop or perform better than the 536 according to lukes post, maybe someone can clear it up for me. The specs are the same except the 536 is 1/4 in diameter bigger than the 644. I would think this would be better because it would give you more surface area. Maybe it performs different or the new motors rather than the gt-40. I had the 856 on my boat for one pull about 2 months ago and took it off right away and got the 536 which I just got put on because the water levels are low. The 856 was horrible on my boat. The hole shot was worse than my OJ plus the rpms were like 500 higher.
Not sure about the 644 as compared to the 536, but the prop on my Limited (non-Team) was not the 536, so the difference to me was significant.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
