Originally posted by Mikeski
They are wired in series, 6 at a time, then the groups are wired in parallel. The LEDs are rated for 2.2 volts so this works well up to 13.2 volts, above that I am starting to push them so I might add a few loops of small gauge wire to induce a little voltage drop. The last group only had 4 LEDs so I had to add a resistor to drop the voltage to that group.
I finally received my LED order from China (actually where 99% of LEDs originate). Now I have a bunch of 5mm 5000mcd (they are bright!) LEDs in Red, Orange, and Blue plus some super bright 5mm White 10000mcd LEDs. I will be using the white ones as backup lights and in my cupholders. I am actually a little concerned about using them in the cupholders because they are so bright, I might need to switch to the Blue ones.
The concept is correct, four in series works for white or blue LEDs. Most Red, Orange, or Yellow LEDs need to have 6 or 7 in series. Technically UV LEDs are not visible so none are bright? However I notice most LED sellers incorrectly show purple LEDs as UV. LEDs are rated in mcd which I believe is the acronym for milli-candela. Generally 5000mcd is referred to as "superbright LED". It is difficult to look directly at a 5000mcd LED without hurting your eyes. These are readily available for reasonable prices so there is no reason not to use them. You can always run them at a lower voltage if you find them too bright, it's easier to reduce the output of a bright instead of increase a dim one.
Electrically speaking you can just wire the LEDs in series to split the voltage down to the desired level:
V(led) = V(source)/number of LEDs
You can also use this equation to determine the resistor needed:
[V(source) - V (led)] / I (led) = R
V (led) and I (led) should be obtained from your LED supplier.
There is also the old trial and error method. Single LED resistors will fall in the 300-600 ohm range on 12-14v systems. Just try different ones until you get what you like. Leave it hooked up for a couple hours, it it gets hot or starts to loose it's punch then you are pushing too much current, increase the resistor value.
