Bilge Pump Switch question
  • hpdixon3
    • Dec 2014
    • 44
    • USA
    What does this switch do exactly when switched all the way down?
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    Bilge B+ goes through the float switch so the pump is automatic if water collects in the bilge, IIRC.
    • hpdixon3
      • Dec 2014
      • 44
      • USA
      So if it's parked at the dock I could just leave that switched on in case water got in? Basically auto bilge without killing my battery?
      • a0128
        • Jan 2014
        • 423
        • Lake Oswego, OR US
        • 1999 Pro Air Nautique
        Per the manual:
        Bilge Pump Only Mode:
        This feature is activated by a switch located below the gauges on the side console. The switch has three positions, on, off and bilge. If the boat is going to sit for more than a few days with the bilge pump on, it is important that the switch is set in the “bilge” position to minimize battery drain. This will activate the bilge pump and shut off power to the Serial Switching and Keyless Ignition System. It is important to remember that the engine or other accessories can not be used unless the switch is in the “on” position.
        Manual can be found here: http://www.planetnautique.com/vb5/fo...uals-brochures
        • hpdixon3
          • Dec 2014
          • 44
          • USA
          Excellent, Thankya
          • homer12
            • Feb 2016
            • 584
            • Indianapolis, IN
            • 2004 SV211 TE
            Couple of questions on this old thread since I'm new to the Nautiques - (1) will the "All Off" position do the same as keeping everything shut off as the Perko battery off switch? (2) Is the "Bilge On" setting wired directly to the battery and not going through the Perko switch? so if the Perko is off the Bilge On will still work?
            • vvfdfirefighter
              • Sep 2015
              • 147
              • Carrollton, VA
              • 2007 Super Air Nautique 220 TE
              The "All Off" switch under the dash ultimately just kills the dash itself. Turning the batteries off at the Perko switch will completely separate the battery from any system in the boat that may have a drawl on it. Including the engine and its ECM. Unless, you have your amps attached directly to a battery and not through the battery switch.
              For question 2, no the bilge only is not attached directly to a battery. You must leave your battery switch selected to a battery for it to work.
              2007 SANTE 220 - ZR 6 Engine (Bought 2015)
              1999 Supra Launch (Bought in 2013)
              1987 Supra Marauder - 454 big block (Bought in 2000 - Sold 2015)
              • homer12
                • Feb 2016
                • 584
                • Indianapolis, IN
                • 2004 SV211 TE
                Thank you sir!
