retro application for NSS
  • Dave Rittiman
    • Apr 2013
    • 209
    • Nor Cal
    • 2009 Nautique 230 Sold 2016 Supra SE450
    Lots of people have been asking me question.
    The lenco switches and pretty nice and look good and allow you to control the wave with 8 different settings so technically you could really refine the wave to you liking. The rams only deploy about 2 inches.
    A few things I came across while installing NSS on a 2009 230.
    • Platform:
      • I had to raise it 2 inches to clear the rams and used 2X2X14 ( might measure the last one depending on your deck).
      • Depending on how you deck mounts you might have to cut and notch the plates out to clear you platform. ( the plates move outword so clear for the movement ).
    • Mounting Plates:
      • ​Buy Extra Screws you sill strip a bunch of them to bolt on the plates.
      • A few of the key mounting points I bought stainless bolts along with nylon locking nuts to drilled all the way through the hull.
        • http://www.lowes.com/pd_189346-73825...d=3826675&Ntt=
        • When you do this make sure you pull the carpet back, what I did was to buy the rubber 12 X 12 rubber tiles and put the rubber over the bolts then glued the carpet over the rubber. I didn’t want it to puncture my 1100 fat sac’s so I tried to make it very clean in the rear lockers.
    • Wake:
      Before NSS Plates
      • 1100 pound Fat Sac in the rear locker that we were surfing on.
      • Center tank filled along with wakemakers piggyback system.
      • 10.6 mph on perfect pass.
    After installing the NSS using the same setup the wave was big and steep when the NSS plate was fully deployed and had a hole in the bottom of the wave.
    Speaking with a few people they said to run 60 / 40 weight with your Fat Sac’s.
    The videos below I had
      • 3 pump cycles in the right rear locker
      • 2 pump cycles in the left locker both bags were 1100 pound fat sac’s.
      • Center Tank empty
    Still working on my setup it looks really promising need to get out and spend a few hours to really figure it out.
    • Hyperlite907
      • Aug 2023
      • 4
      • ON
      • 2011 Super Air Nautique 210
      Dave Rittiman how did you get your hands on the NSS for a boat older than 2012?
      • swatguy
        • 1631
        • Midwest/ Northern IL
        • 2008 SANTE 210
        Youcan order the plates straight from
        Nautique. If they’re no longer in stock or Available. There is a guy named Max on this site who fabricated replicas do search for his name
        https://www.wakegarage.com/projects-...-for-210-r164/
