the marina that shrink wrapped my boat last fall apparently it something with the tower and jacked it up pretty good (just noticed last weekend when I put it in the water)...need a 2nd gen FCT (i think thats what it's called...factory tower from ~2000-2003)...any body know where one might be hiding??
No I'm not sure. Took measurements with it sitting on ground and not mounted on a boat. They were: Width/beam @ rear mounts is 84". Width/beam @front mounts is 76". Length from front mount to rear mount is 71". Rear mounting plates are rectangle and front mounting plates are circular. Didn't measure the size of those but I can if you want them. Give me a call if you want @ 256-393-8268
