OJ 16"x15" for the 550hp boats --FINALLY--
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    #76
    OJ 16x16, ~7000lb G23 and a ~4300-4500lb ballast NSS surf setup.
    Went real fast on this to keep the video short.
    https://vimeo.com/130590532
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • JoeA
      • Jun 2014
      • 808
      • Chickamauga Lake TN
      • 2015 G23 550
      #77
      Well done Ryan
      2015 G23 550
      2013 Malibu 22MXZ
      • ironj32
        • May 2011
        • 601
        • 2018 SAN G23 XR550
        #78
        Originally posted by JoeA View Post
        Irony,
        What are the specs on the next one you plan to test?
        Not 100% sure, yet. I think it'll be a 16x14.75.
        2018 SAN G23 XR550
        2015 SAN G23 XR550
        2014 SAN G23 XR550
        2013 SAN G23 XS550
        2013 SAN G23 ZR450
        2011 SAN 230
        2010 SAN 230
        2000 XStar
        www.mnspringride.com
        • JoeA
          • Jun 2014
          • 808
          • 2015 G23 550
          #79
          Please post your results after testing. Very interested in the performance, RPMs and fuel consumption.
          2015 G23 550
          2013 Malibu 22MXZ
          • nyryan2001
            • Mar 2013
            • 1993
            • Lake Anna
            #80
            Substantiates the 20% fuel savings:
            14 June
            184.3 start 191.4 end 7.1hrs total. Shell 93. Mixed use, cruise and some heavy wake surfing. 40.7 Gals total used. 5.73 Gph average.
            2019 G23 450
            2014 G23 550
            2013 G23 450
            2007 Yamaha AR210
            • robertsmcfarland
              • Oct 2004
              • 544
              • Hyco
              • 2014 g23 550
              #81
              wow so much information one gets a little confused ,,,, so in plain English,,, whats the best prop for (saving gas , reducing rpm, hole shot same or better} while doing surf and boarding 50/50....with 1000 pounds of lead that stays in boat at all times.... and pro settings used on linc... thanks in advance....
              2013 G23 super air
              2010 230 super air
              2009 220 super air
              2008 210 super air
              2005 210 super air
              2003 calabria pro air
              • nyryan2001
                • Mar 2013
                • 1993
                • Lake Anna
                #82
                Robert, really depends on how you use your boat and what your priorities are. I can describe effects, you gotta choose what best aligns with your priorities.
                If you wanna save a lot of gas while surfing heavy 16x16 all day. 16x16 is an A++ G550 surf prop for most any weights, better than OEM. But your heavy 24mph wake performance will suffer some. If OEM ballast is your max for 21-24mph wakeboard... you'd be fine with the 16x16. If you need to save gas for money, or to get through long weekends without a fillup as a priority... 16x16 is your prop. If you have long cruises to get to your spots, 16x16 is your prop.
                If you are looking for bonkers weight over OEM ballast at 21-24mph wake speeds, you need a 16x15 to 16x14.5. 16x15 you'd save a little gas vs OEM.... any smaller pitch than that gas savings will be negligible if any, but heavy 21-24mph performance will A+.
                You gotta determine where you are on this spectrum and what your priorities are. Really cant be anymore clear than what I've described. There is no silver bullet, and there are trades with any of these prop decisions.
                At this point I think I've beaten this to death from the surf side of things... some of the other guys who run really heavy weights at 24mph can chime in. Next week I will have some really advanced riders behind my boat.... and have no worries whatsoever the 16x16 will do fine with max OEM ballast and folks onboard.
                2019 G23 450
                2014 G23 550
                2013 G23 450
                2007 Yamaha AR210
                • robertsmcfarland
                  • Oct 2004
                  • 544
                  • Hyco
                  • 2014 g23 550
                  #83
                  Thanks ,, that breakdown clears things up for me,I jump the gun and got the 16x15.5 and then started reading about the other props you are testing testing,, have not put the 16x15.5 on yet, drop the shaft key in water, and could not find... as you know its specially made for the 550,, also have appointment for warranty shaft replacement next week didn't want the the 16 to void warranty if the shaft broke...
                  2013 G23 super air
                  2010 230 super air
                  2009 220 super air
                  2008 210 super air
                  2005 210 super air
                  • nyryan2001
                    • Mar 2013
                    • 1993
                    • Lake Anna
                    #84
                    doh! lost the shaft key.... only way to get a new one for the bigger shaft is through a Nautique dealer?
                    2019 G23 450
                    2014 G23 550
                    2013 G23 450
                    2007 Yamaha AR210
                    • robertsmcfarland
                      • Oct 2004
                      • 544
                      • Hyco
                      • 2014 g23 550
                      #85
                      its coming this am to my work,,,, White lake came to my rescue ...as always...
                      2013 G23 super air
                      2010 230 super air
                      2009 220 super air
                      2008 210 super air
                      2005 210 super air
                      • bradw
                        • Feb 2013
                        • 108
                        • Australia
                        • 2015 G23 XR550
                        #86
                        IronJ32
                        How did you go with the 16x14.75?
                        • ironj32
                          • May 2011
                          • 601
                          #87
                          I haven't gotten the 16x14.75, yet.
                          2018 SAN G23 XR550
                          2015 SAN G23 XR550
                          2014 SAN G23 XR550
                          2013 SAN G23 XS550
                          2013 SAN G23 ZR450
                          2011 SAN 230
                          2010 SAN 230
                          2000 XStar
                          • rjhanks
                            • Jun 2015
                            • 2
                            • Puyallup
                            • 2015 G25 550
                            #88
                            You guys think everything would be similar with a G25 550?
                            • nyryan2001
                              • Mar 2013
                              • 1993
                              • Lake Anna
                              #89
                              Yeppers. how are you looking to change the performance of yours from how it performs on the OEM 15x14.25?
                              2019 G23 450
                              2014 G23 550
                              2013 G23 450
                              2007 Yamaha AR210
                              • rjhanks
                                • Jun 2015
                                • 2
                                • Puyallup
                                • 2015 G25 550
                                #90
                                I've only had the boat for a week and compared to my old malibu 247 it gets out of the hole and on plane like a rocket. Would probably like a little better fuel efficiency so was thinking the 16 x 15.5 or the 16 x 16. I have a few weekends a year where we really load it down but other than that its just the wife and the kids with me wakeboarding.
