OJ 16"x15" for the 550hp boats --FINALLY--
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    #91
    Last week using the OJ 16x16 I had full 2850 OEM ballast, +750ish lbs of assorted crap, and 8 adults on board....I was towing an advanced rider at 24.5mph and with NCRS cranked up to 5 I was turning 3300rpms. It was a bit sluggish getting up to speed...gotta ensure NCRS is a 0 on takeoff....more weight in the bow helps. I ran harder and heavier then I ever have then and still managed 7.9gph. Average use I am seeing around 6gph on the OJ 16x16.
    for max fuel savings and low RPMs all around, A+ for surfing heavy weights: OJ 16x16. (Performance will lag some getting up to 20-25mph heavily ballasted)
    for serious 20-25mph wakeboarding, fuel doesn't matter, all about performance 3-6000lbs ballast: OJ 16x~14.5ish.
    16x15 and 16.15.5 are in between on that spectrum.
    Enjoy!
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • bradw
      • Feb 2013
      • 108
      • Australia
      • 2015 G23 XR550
      #92
      Any updates from wakeboarders running the 16" prop and some extra ballast? Hows the prop preform?
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        #93
        If you wanna go bonkers heavy ballast at 23-24mph.... OJ 16" x 14.75".
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2007 Yamaha AR210
        • thedude
          • Apr 2007
          • 451
          • SW PA
          #94
          Ryan, in your opinion, do you believe one could realize similar efficiency gains with a 2013 G23 with the zr450 by going with the 16x15? Main use is wakeboarding, OEM ballast + 2 adults on board, 22.5 mph. Goal would be to drop RPMs by about 250 or so vs. the stock 2313 prop, increase fuel efficiency to squeeze in more times between fill-ups, and decrease RPMs at cruising speeds. Maybe a 15.5x15 prop? I know apples to oranges vs. your tests, but similar theory might apply. Thanks in advance.
          • nyryan2001
            • Mar 2013
            • 1993
            • Lake Anna
            #95
            Dude, no, no way a 450 on a 1.48:1 could spin that prop well.
            Now, with that being said... If I had a 2013 450, I'd be looking at a 16x12... Or a 16x11.5. Having had both a 450 and a 550, I wouldn't want to give up ANY performance at any cost.
            2019 G23 450
            2014 G23 550
            2013 G23 450
            2007 Yamaha AR210
            • jesutton3
              • Nov 2010
              • 93
              • Raleigh
              #96
              Any more info on the 16" props for wakeboard speeds?
              • nyryan2001
                • Mar 2013
                • 1993
                • Lake Anna
                #97
                jesutton,
                The 16x16 is perfect for any and all surfing, including very heavy surfing. The 16x16 works well for OEM ballast at 23mph... a slight loss in performance compared to the OEM prop, a little slower getting 0-23mph. But the 16x16 will lower your RPMs across the board, 300-600rpms and save you a lot of gas over the OEM prop and run lower RPMs.
                If you run heavy weight over OEM ballast at 23mph, the 16x16 is not for you. If you go heavy weights over OEM ballast at 23mph, you aren't saving gas anyhow, it all about performance, you want a 16x14.5 sized prop, may have a slight advantage over the OEM prop.
                2019 G23 450
                2014 G23 550
                2013 G23 450
                2007 Yamaha AR210
                • Devodad
                  • Jan 2014
                  • 13
                  • Minnesota
                  • 2018 G23 H6 2013 G23 450 2006 Mastercraft X 45
                  #98
                  Still a little confused.
                  Which 16" prop would you recommend for a heavily weighted 2013 G23 with a 450?
                  Thanks.
                  • Devodad
                    • Jan 2014
                    • 13
                    • Minnesota
                    #99
                    Mainly for wakeboarding.
                    If we go to a 16x14.5 size prop will the boat perform better with more weight?
                    • ironj32
                      • May 2011
                      • 601
                      • 2018 SAN G23 XR550
                      #100
                      Of those that I know exist and have experience with, I'd check out the Acme 2315. It's what I ran on my 2013 G w/ the 450. It is a 15x12, but has less cup than the factory 2313. You'll run a bit higher RPM, but should see a better hole shot, and maintain speed in your tighter turns. I'm not sure if they make 16" props with the 1 1/8" bore or not?
                      2018 SAN G23 XR550
                      2015 SAN G23 XR550
                      2014 SAN G23 XR550
                      2013 SAN G23 XS550
                      2013 SAN G23 ZR450
                      2011 SAN 230
                      2010 SAN 230
                      2000 XStar
                      www.mnspringride.com
                      • nyryan2001
                        • Mar 2013
                        • 1993
                        • Lake Anna
                        #101
                        Devo- Acme 2315 15x12 for you, 450, 1.48:1 tranny.
                        If you feel froggy and wanna experiment, look at a custom 16x12 or 16x11.75.
                        2019 G23 450
                        2014 G23 550
                        2013 G23 450
                        2007 Yamaha AR210
