When do I use the Belly ballast ??
  • Ccamp2
    • May 2015
    • 25
    • Peoria Illinois
    • 2010 Air Nautique 216V LE
    I am still learning my boat and have a 2010 216v LE.. I has 3 hard tanks, 2 in back and 1 in belly. Last night I filled the back 2 only and had the Hydro Gate on 3. (only 2 adults onb board) I wasnt really satisfied with my wake.
    When is the appropriate time to use the belly tank?
  • cedarcreek216
    • Oct 2009
    • 1009
    • Dallas, TX
    • 2018 210 2013 210 2009 216V
    Are you asking in regards to surfing or wakeboarding? Either way, on that boat belly ballast is always your friend. We filled ours for every sport, including slalom skiing. It helped get the butt out of the water. If you are looking for a surf wave out of stock ballast it won't happen, just not the hull for it.
    • Ccamp2
      • May 2015
      • 25
      • Peoria Illinois
      Just wakeboarding sir.. For some reason I was thinking that for wakeboarding I would want the butt in the water as much as possible ??
      • vision
        • 517
        • NC
        • 2013 G23
        For 211s/216s, they have a better wakeboard wake when they are weighted more evenly.
        • migs
          • Aug 2008
          • 703
          • San Mateo, CA
          • SAN 210 TE
          You should fill all the ballast tanks.
          Migs
          G21 - En route
          SAN 210 TE (Finally)
          06 Sky Supreme V220(previous)
          05 Sanger V210(previous)
          01 MC X1(previous)
          99 Air Warrior(previous)
          • ironj32
            • May 2011
            • 600
            • 2018 SAN G23 XR550
            In most boats, for wakeboarding, you'll want to utilize all of the factory ballast. If you end up adding additional ballast, keep the ratios of rear:front weight close to what the factory ratio is. From there, you can make slight adjustments to tailor the wake to your liking.
            2018 SAN G23 XR550
            2015 SAN G23 XR550
            2014 SAN G23 XR550
            2013 SAN G23 XS550
            2013 SAN G23 ZR450
            2011 SAN 230
            2010 SAN 230
            2000 XStar
            www.mnspringride.com
            • 4th ski-doo
              • Apr 2013
              • 307
              • Wilmington
              • 2013 SANTE210 2011 Sport200V 1994 Bimini Skier 190 1986 Master Craft Pro Star 190
              Surfing or boarding, even weight is best.
              2013 SANTE 210
              2011 Sport 200 V
              1994 Bimini Skier Pro 190
              • s_kelley2000
                • 1575
                • Fort Meadow Recevoir
                • Mass
                This advice is spot on. Just to add to the part about tailoring it to your liking, in general more weight in the front will make the wake rampier while more weight in rear will make it steeper.
                Shawn
                2012 Blue Metal Flake SAN 230
