Piggyback sack venting issues...
  • theskunk
    • Oct 2014
    • 232
    • Stafford, VA
    • 2006 sv-211
    2006 SV-211... Adding a sack on top of the hard-tank for surfing.
    Also added one to the ski locker - no issues there.
    I've seen a few other posts about putting a small tube in the sack to prevent a vacuum from forming and preventing things from draining properly. I'm considering doing this, but I'm also considering putting the sack on a T, and then letting gravity do the work of draining it, putting no vent directly on the bag itself. I figure if I have a small issue with gravity "running out of steam", If it's draining at the back, then theoretically just plowing water with the nose high will keep it draining, OR I can just reach over and put my hand on the vent on the side of the boat and force it to squeeze the sack a bit.
    Thanks!
  • d_nodixon
    • Sep 2008
    • 475
    • Hammond, LA
    • 2013 SAN 230
    You can also put in a t check valve between the bag and tank so that it opens and allows air in when the vacuum begins
    2013 SAN 230
    2006 SSN 210 (SOLD)
    • theskunk
      • Oct 2014
      • 232
      • Stafford, VA
      • 2006 sv-211
      Now that would work... Let me draw a picture and get a consensus from the masses....
      • theskunk
        • Oct 2014
        • 232
        • Stafford, VA
        • 2006 sv-211
        This look about right?
        • theskunk
          • Oct 2014
          • 232
          • Stafford, VA
          • 2006 sv-211
          This is the other option I've been considering
          • faralta
            • Aug 2013
            • 18
            • Clarklake, MI
            • 2006 sante 210
            Here's my diagram, http://www.planetnautique.com/vb5/fi...4&d=1422279896, from this thread, http://www.planetnautique.com/vb5/fo...-2004-san210te
