New Member and glad to be here but need help!!!! No Bashing please just help!! Thanks
  • Nordicron
    • Sep 2009
    • 557
    • Madison, WI
    #61
    That's pretty cool that Eric went over to your boat and turned pumps on for u. Why were they turned off? Initially it seems to me perhaps between u and the dealer maybe communication was broken down a bit. Maybe u and them both assumed some things that shouldn't have been assumed.
    Didn't u leave your past boats in the slip with the pumps on auto? Again not to place blame but it does seem like it's your responsibility here that the boat flooded. U knew it was leaking and left it sitting in a slip unattended and apparently with pumps off?? Now again as I've said before they collected a massive amount of money to "fix" this and it's not fixed? That's this issue I think. Again not saying u messed up the strainer but u should have done something to get your leak figured out. Whether that be pull boat out of water or watch it like a hawk or stick your own head in there and find the leak yourself, u needed to do something other than just call the dealer and say it's got a leak.
    • FRG
      • Jun 2004
      • 54
      • FOX RIVER GROVE, IL
      #62
      Foster,
      Are you now ganging up with the other G owner that beaches his boat, mud packed his engine so bad that they had to replace the engine? Just Sayin!
      • Quinner
        • 2246
        • Correct Crafts
        #63
        Did a surfer just call a tuber obnoxious, lol
        • swatguy
          • 1631
          • Midwest/ Northern IL
          • 2008 SANTE 210
          #64
          Now this is getting interesting. Hahahahahahah
          • Nordicron
            • Sep 2009
            • 557
            • Madison, WI
            #65
            Lol! Luv it!
            • a0128
              • Jan 2014
              • 423
              • Lake Oswego, OR US
              • 1999 Pro Air Nautique
              #66
              I would think that if the strainer was cross-threaded at the factory the water leakage would have been noticed when Nautique does their water test during the manufacturing process. Assuming all was well (strainer correctly threaded and NOT leaking) and the boat passed final inspection at the factory then the next time the strainer SHOULD have been looked at would be during dealer acceptance from the factory (as part of an overall check before any water tests / demos). Again assuming the strainer was correctly threaded and NOT leaking then how does it become cross-threaded post-purchase?
              A big red flag for me is the mention of the fact that the lake you operate on has a mud bottom and that you apparently beach your boat on the mud bottom. Given how powerful the RWP is I can only imagine that upon starting the engine while beached is going to cause the pump to ingest a considerable amount of mud, sand and debris. All this is going to collect in the strainer eventually clogging it and reducing water flow to the engine. Once this happens the strainer must be unscrewed and cleaned. This may also explain your high engine temp warnings.
              I am concerned we are all being taking for a ride here and being given a small sampling of facts but not the full story.
              Since you've had an opportunity to state the facts as you recall them and you've received responses both in support of and in question of your situation it is now time for you to go away. Your problem is not going to get solved on this forum. If you believe you have a negligence case against the dealer you should seek competent legal representation and pursue justice in a court of law.
              If your goal was to elicit opinions and solutions to your predicament from the forum members, then you have achieved that to the degree in which you have (or have not) correctly stated the facts at hand. In either case I doubt there is anything more we can do for you here, so please go away and enjoy your boat.
              • migs
                • Aug 2008
                • 703
                • San Mateo, CA
                • SAN 210 TE
                #67
                OH NO HE DIDNT!
                Migs
                G21 - En route
                SAN 210 TE (Finally)
                06 Sky Supreme V220(previous)
                05 Sanger V210(previous)
                01 MC X1(previous)
                99 Air Warrior(previous)
                • obd666
                  • Feb 2010
                  • 793
                  • Bostian Heights, NC
                  • 03 SANTE
                  #68
                  you had me at LOL
                  2003 SANTE - "OG 210"
                  • Paxdad
                    • Mar 2013
                    • 775
                    • Cumming, GA
                    • 2008 210 SANTE
                    #69
                    Originally posted by NautiqueJeff View Post
                    Just a friendly reminder to everyone that all members here are required to follow the site TERMS OF USE, which you all agreed to when you registered here. Please be respectful in your posts. Thanks!
                    PlanetNautique.com Terms of Use
                    Original: October 25, 2005
                    Updated: December 22, 2014
                    v1.5
                    Short and Sweet:
                    ยท Post messages under the correct topic.
                    ยท Show respect to other people using this board. No personal attacks or insults are allowed.
                    ยท Do not post messages that are libelous, defamatory, obscene, abusive, pornographic, racist, threatening or an invasion of privacy.
                    ยท Do not post messages that are an infringement of intellectual property rights, including, copyrights and trademarks, of any person or entity.
                    ยท Do not post messages that discuss activities that are illegal in any way or which advocate illegal activity.
                    ยท Keep it clean. No swearing or inappropriate language is allowed.
                    ยท Users are speaking for themselves, their statements and opinions do not necessarily reflect those of PlanetNautique.com.
                    So far so good but the reference to tuber and G23 is borderline abusive. I dont think in 2 years of posting that I have seen a thread get this many replies in such a short amount of time.
                    NautiqueJeff,
                    Is this like a record or something??
                    2008 210 SANTE
                    • NautiqueJeff
                      A d m i n i s t r a t o r
                      • Mar 2002
                      • 16558
                      • Lake Norman
                      • Mooresville, NC
                      #70
                      This one has grown pretty quickly for sure.
                      I have removed a couple of posts that clearly violated the terms of use. There are a few others that are questionable, but I think I'll leave them for now as long as it doesn't get too crazy.
                      Current Boats โ€”> 2025 Super Air Nautique G23 -- 2001 Ski Nautique -- 2000 Nautique Super Sport PYTHON -- 2000 Nautique Super Sport -- 1999 Ski Nautique PYTHON-- 1985 Sea Nautique 2700 (Twin-Engine, 1 of 13) -- 1981 Fish Nautique (Twin-Engine, 1 of 4) -- 1980 Fish Nautique (Twin-Engine, 1 of 4)
                      Former Boats โ€”> 2024 Super Air Nautique G23 PARAGON -- 2023 Super Air Nautique G23 --
                      โ€‹2022 Super Air Nautique G23 PARAGON -- 2021 Super Air Nautique G23 -- 2021 Super Air Nautique G23 -- 2020 Super Air Nautique G23 -- 2019 Super Air Nautique G23 -- 2018 Super Air Nautique G23-- 2018 SAN 210 TEโ€‹ -- 2017 Super Air Nautique G23 -- 2016 Super Air Nautique G23 -- 2015 Super Air Nautique G23 -- 2014 Super Air Nautique G23 -- 2014 Super Air Nautique 230 Team Edition โ€” 2013 Super Air Nautique G23 โ€” 2012 Super Air Nautique 210 Team Edition โ€” 2011 Super Air Nautique 210 Team Edition โ€” 2010 Super Air Nautique 210 Team Edition โ€” 2008 Super Air Nautique 230 Team Edition โ€” 2007 Air Nautique 236 Team Edition -- 2007 Air Nautique SV-211 -- 2005 SV-211โ€‹ -- 2003 Super Air Nautique 210 Team Edition -- 2003 Air Nautique 226 -- 2003 Sport Nautique 216 -- 2003 Ski Nautique 196 -- 2003 Ski Nautique 196โ€‹-- 2002 Ski Nautiqueโ€‹ -- 2001 Sport Nautique -- 2001 Ski Nautique -- 2000 Sport Nautiqueโ€‹ --โ€‹ 1999 Ski Nautique Open Bow -- 1999 Air Tique 176 -- 1998 Ski Nautiqueโ€‹ -- 1998 Ski Nautique -- 1998 Ski Nautique -- 1997 Ski Nautique -- 1997 Ski Nautique -- 1996 Ski Nautique Open Bow -- โ€‹1994 Ski Nautique -- 1993 Barefoot Nautique -- 1983 Fish Nautique (TWIN ENGINE, 1 of 4) -- 1981 Fish Nautique (SINGLE ENGINE)
                      • luxuryfoster
                        • Jun 2015
                        • 16
                        • crystal lake il
                        • 2014 Nautique G23 550Hp
                        #71
                        Guys thank you for your comments positive or negative. It appears that ALL they guys over at Boat House are going to help me out in this unfortunate situation just in time for July 4th weekend. At this point I'm thrilled!!! I'll keep everyone posted.
                        Thank you
                        • swatguy
                          • 1631
                          • 2008 SANTE 210
                          #72
                          Well that took a 180.
                          • Quinner
                            • 2246
                            • Correct Crafts
                            #73
                            Say no to power turns!!
                            • JoeA
                              • Jun 2014
                              • 808
                              • Chickamauga Lake TN
                              • 2015 G23 550
                              #74
                              If he's on the water by Saturday its a win-win for all
                              2015 G23 550
                              2013 Malibu 22MXZ
                              • Tallredrider
                                • Oct 2014
                                • 1026
                                • St. George, Utah
                                #75
                                I can't believe that I just read all 5 pages.
                                Here is my understanding of what happened: There was a leaky water strainer on the boat, and he left the boat on the dock and shut off the batteries as many people do who leave their boats without planning on using them for a while. Boats are notorious for small electrical gremlins that will give you dead batteries. How many times do you guys see people at the ramp with dead batteries? I have seen it more times than I can count. With the batteries off, the bilge pump no longer works, and he gets his boat full of water.
                                Dealer thinks he is a DA for shutting off the batteries when he knew he had a leak somewhere. He thinks dealer should have told him so, and that they should have found the leak in the first place.
                                One of my off season improvements will be to wire the bilge pumps like they should have been from the factory. I find it unbelievable that Nautique does not wire the bilge pumps directly to the batteries so that they could never be turned off. Imagine the pain and suffering that all sides have suffered because Nautique does not do this simple thing! My MC was wired straight to the battery, my Tige was too. My Malibu was not, so Nauti is not alone, but they are also not in line with at least a couple of others. I hope that they will fix this in future years. Maybe Foster's Supra was wired straight to the battery so maybe he never imagined he was removing his boat's life support when he cut the switch.
