We have a 2014 SAN 210. I think the weight limit is something like 12 people and or 1850 lbs. We have like 1250 lbs of factory ballast that I fill up when we surf. I have purchased 2 ronix 800lb sacks for the rear lockers and 1 600lb bow sack. I guess my concern is the additional 2200 lbs that I'm adding. Will I have engine issues here? We have just the stock 343 engine.
Tags: None
You shouldn't have any issues, especially for surfing. If you wakeboard as well, may need to move a little more weight forward to get it to plane out. Of course, more weight is more strain on an engine, but we have put thousands of hours with that much weight or more on boats and haven't seen any issues.
That weight limit already takes full factory ballast into consideration. It assumes that ballast is already full.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I'm not even sure what prop I have. Its just the stock one though. Jeff I'm running the factory ballast at the 1250lbs. I'm also running with the 2200 extra lbs in the ronix aftermarket bags so there is a significant amount of additional weight to the already factory ballasts
I run 2400 lbs of ballast with an Acme 1617 prop surfing. No issues at all
