'99 Sport - replace hard tanks with which sacks?
  • MuskokaCanada
    • Aug 2012
    • 74
    • Ontario, Canada
    • 1999 Sport Nautique
    If you pull the hard tanks out of your '99 era Sport Nautique, which sacks fit best into the stock location? Did you keep the factory fill / empty design and hardware?
    Mine is still new to me and I haven't even figured out how it works. Or mine doesn't work and that's why I haven't figured it out yet. The duct tape residue around (what I assume to be) the fill location on the bottom of the hull ... isn't a good sign, IMHO. I should have taken a pic
  • Tom351
    • Oct 2011
    • 93
    • Chapel Hill, NC
    My 99 Sport did not have factory ballast so I did not have to remove hard tanks and I installed my own fill/empty system with a reversible pump.
    I used this in the ski locker:
    http://www.wakemakers.com/fly-high-tube-sac.html
    And this one in the rear locker:
    http://www.wakemakers.com/straight-l...o-800-sac.html
    I made sure to add vent lines to both as I was concerned that they could overfill and damage fiberglass.
    1986 Silver Nautique
    1999 Sport Nautique
    • MuskokaCanada
      • Aug 2012
      • 74
      • Ontario, Canada
      So you had no intention of trying surfing with your boat? Or you just add people to one corner when you want to surf?
      • rbalan
        • 328
        • Georgia
        • 2002 SANTE
        Most Sport/Air owners put 2 sacks in the back including myself. If I was to do it all over again, I would go with one for simplicity knowing that trying to get a good surf wave is almost impossible.
        • MTRBTR
          • May 2012
          • 485
          • MT
          Impossible? I surf my 97 all the time.
          To the OP do you have a 99 Super sport v-drive? or just a sport. I didnt think the 99 sports had ballast. If it is a Pro-Air it would.
          2006 SV 211 (Sold)
          97 Sport Nautique (Sold)
          89 PS 190 (Sold)
          75 MFG (Sold)
          • MuskokaCanada
            • Aug 2012
            • 74
            • Ontario, Canada
            It says Sport Nautique on the side but came with two ballast tanks and a tower from the factory.
            • Treybizttu
              • Sep 2014
              • 345
              • Grapevine
              • 99 Super Air Python
              I have a pro air but it's similar configuration... I pulled the hard tanks out and stuck some 600lb Sumo Sacs Back there using the stock switches, new hoses, new pumps. I ended up running the drain pump out of the vent holes on the transom which works great. However, I have so many hoses and pumps and bags and what not back there it looks like an octopus. Next time at the lake I'm going with a single 800lb bag, removing one empty pump since I have two and lots of hoses. Simplify a little.
              I'll keep my 2x 600lb bags for extra seat weight using a cig lighter plug in pump.
              Also going to order a 325 center locker bag that will just be filled with the plug in pump as well.
              • Tom351
                • Oct 2011
                • 93
                • Chapel Hill, NC
                I am mostly a slalom course skier and occasional wakeboarder... Have not tried to surf this boat yet, but I did also make an extra fill line connection where I can plug in a hose with a quick connect into the system to fill extra bags on the floor...This way if I do want to use bags on the floor I can easily tap into the reversible pumps for fill/empty and not have to mess with cigarette lighters and aerator pumps.
                1999 Sport Nautique
