Finally, my custom NSS
  • jjsaustin
    • Sep 2012
    • 40
    • Austin
    • 2006 226
    Great job! The video results shows that you nailed this. How much does your a plate slide out and down? Can you please post some more pics of the side of the boat and how you filled the gap from the rounded hull using the shim. How did you make the shim and shape it to match your hull?
    Also in the video what was the ballast setup?
    Thanks and congrats
    • max 1.6
      • Oct 2014
      • 284
      • Canada
      • 2009 Nautique 230
      I don't have pictures of the sides at the moment. What I can tell is that it's not "flush" with the hull because the curve of the transom at this place is really intense. There is a 1/4 in gap which doesn't affect water flow when riding with retracted plates.
      On the video I was only riding with hard tanks full because it was a test ride to show the system. Later that day I tried with hard tanks + ballasts. It gives me 2200lbs in the back and 1200lbs in front. The wave is huge, I'm 205 and I can run a 4'8" board as far as 20ft behind the boat.
      • Dave Rittiman
        • Apr 2013
        • 209
        • Nor Cal
        • 2009 Nautique 230 Sold 2016 Supra SE450
        Max
        I have been doing 60 / 40 or 70 / 30 weight in the fat sacs with pretty good results. I have 1100 pounds fat sacs and a piggy back belly fac think its 600 pounds ( I took out the hard tanks in the rear ).
        NSS setting with the Lenco switches in the 7th position out of 8.
        So basically I have been filling the fat sac completely on the the surf side then the other fat sac around 1/2 to 3/4 full.
        Kinda weird some days it looks huge and others looks smaller.
        • max 1.6
          • Oct 2014
          • 284
          • Canada
          • 2009 Nautique 230
          I did it, more like 60-40. very good results and not that long to switch.
          • max 1.6
            • Oct 2014
            • 284
            • Canada
            • 2009 Nautique 230
            For those who wanted to see. Here is the wave with full ballast on port , 3/4 starboard and belly+arrow in the front
            https://youtu.be/QGvbsLunCgk
            Sorry there was some traffic so the other waves hits mine but you can see what it gives
            • Nealcj8
              • Jul 2015
              • 4
              • Florence Alabama
              • 2004 Air Nautique 226
              #21
              Has anyone built some of these for a 226 yet? I just bought my 04 about a month ago and I am still trying to get my surf wake right and these seem to make a huge differance.
              • max 1.6
                • Oct 2014
                • 284
                • Canada
                • 2009 Nautique 230
                #22
                AndrewC made one for a 226. The transom is more curved than a 230, more work is involved.
                • cedarcreek216
                  • Oct 2009
                  • 1009
                  • Dallas, TX
                  • 2018 210 2013 210 2009 216V
                  #23
                  Pretty sure AndrewC has a 220
                  • max 1.6
                    • Oct 2014
                    • 284
                    • Canada
                    • 2009 Nautique 230
                    #24
                    Oh my bad....
                    Then I don't know about a 226
                    • cedarcreek216
                      • Oct 2009
                      • 1009
                      • Dallas, TX
                      #25
                      The 226 is the same hull as the 230 from what I understand.
                      • max 1.6
                        • Oct 2014
                        • 284
                        • Canada
                        • 2009 Nautique 230
                        #26
                        236 and 230 share the same hull. Would be surprised about the 226 also....
                        • sc8tt
                          • Jun 2012
                          • 111
                          • smith mountain lake virginia
                          • 2005 226 TEAM
                          #27
                          I also have a 226 (2005). super curious. What's a ballpark cost in putting this together?
                          2005 226 TEAM
                          • cedarcreek216
                            • Oct 2009
                            • 1009
                            • Dallas, TX
                            #28
                            Now it's my bad, missed 226 and thought it said 236. Not sure what the hull on the 226 is like but it can't be far off from the 236.
                            • Nealcj8
                              • Jul 2015
                              • 4
                              • Florence Alabama
                              #29
                              It is just a scarry thought to drill holes in the back of my boat just to experiment with something like this. But it would be a great upgrade.
                              • max 1.6
                                • Oct 2014
                                • 284
                                • Canada
                                • 2009 Nautique 230
                                #30
                                A bit scary but nothing is "irreversible". You could redo some fiberglass and gelcoat in the happening of a major mistake.
                                Pretty sure a system like that adapted to a 226 would do a great job.
