Water coming through walkway 2015 210
  • lucky7t
    • Mar 2011
    • 1306
    • Oklahoma
    • 2015 SANTE
    Anyone else have an issue with water coming in rear walkway when you stop while surfing ??
    Had about 5 inches of water in hull after one day of surfing.
    Current Correct Craft Boat
    Correct Craft Boats Owned
  • Whitetail15
    • Apr 2010
    • 603
    • 2016 G23 H6
    It is an a absolute must to turn hard rt and back off the throttle at same time when surfer falls. This does two things. One the wave does not come in back of boat because it is no longer facing that way. And two it allows you to wait and turn in side the rollers so you can go back to get your fallen rider with the waves coming in the front as well.
    2016 G23
    • swankster
      • Aug 2010
      • 1052
      • DFW, TX
      If you have a goofy footer then turn to the left. The other thing you can do it back off the throttle slower. The same thing can happen in a G if your tanks are full and you pull back on throttle to fast when pulling a boarder. It doesn't happen when surfing.
      2010 SANTE 230 343 (280hrs)
      • F725
        • Feb 2013
        • 381
        • Minnesota
        • 2018 G21
        I've never had water over the back walk-thru. I typically turn when backing off the throttle but there has been times when I couldn't. I have 2k in ballast in rear lockers and never an issue. But I also never just slam the throttle into neutral from surf speed either.
        • lucky7t
          • Mar 2011
          • 1306
          • Oklahoma
          • 2015 SANTE
          This is a 2015 210 with the walk through . It's factory ballast with the factory upgraded ballast. If you stop to let the waves hit the back of the boat then water comes into the boat. I've had multiple Nautiques but none had walkthroughs and never had this issue. Nautique needs to address this issue . I don't power turn . I stop and slowly go back to surfer . I'll try the turn left (goofy) while stopping .
          • F725
            • Feb 2013
            • 381
            • Minnesota
            • 2018 G21
            Yup ours has the walk thru also. When the rider falls pull back slowly on the throttle and turn away from the surf wave. The only way for Nautique to "fix" this would be to remove the walk thru. That would be a step backwards.
            • Tallredrider
              • Oct 2014
              • 1026
              • St. George, Utah
              This happens almost every time while wakeboard on the G23. I don't think it is all that much of a pressing need to address. It is easily fixable with a change of driving habits.
              I've always had a joke whenever I see someone get in the boat dripping wet that I yell at them not to get the boat wet. I don't mind if my boat gets wet while I'm at the lake.
              • lucky7t
                • Mar 2011
                • 1306
                • Oklahoma
                • 2015 SANTE
                Thanks for the replies. I tried the turn when stopping and yes it stops it. Now I have to teach the wife
                Thank you for the advise
                • Kelly Gummere
                  • Aug 2015
                  • 38
                  • Memphis, TN
                  • 2014 SAN 210
                  I have a 14' SANTE 210 with 2 800lb sacks in the rear lockers as well and a 600lb in the bow and have yet to have the water come in the back. I have had the water come over the bow when I'm turning into the waves though. That is also with me pulling the throttle back immediately when the surfer falls. Now I throttle back and wait for the waves to pass. Then I turn back and has stopped the waves coming in the bow.
                  • deelan
                    • Jul 2015
                    • 90
                    • Denton, TX
                    • 2015 SAN 210
                    I have 2015 210 with 750lb in each rear compartment and it has never came thru the walk way. When surfing we throttle down (sometimes fast and sometimes slow) it has never been an issue. We wait till rollers go by then we turn back to get the rider.
                    I know G's have this prob but not my 210.
                    • nautiques4life
                      • Jan 2009
                      • 696
                      • SoCal
                      Sounds like you guys never drove old 94-97 sports weighted down to ride back in the day. With its heavily sloped rear and low freeboard all serious OG riders had to learn how to properly stop. Turning works ('cause obviously if your rider falls you're probably going to turn around and get them), or if you're not turning for some reason, you can always do the old school stop. If you claim it happens everytime you ought to be prepared for it- all you have to do is not drop all the way into neutral, and give it a little gas as the wave comes- its kind of a two part move, but the roller won't go near your rear pads if you pull away as it comes up.
                      • vision
                        • 518
                        • NC
                        • 2013 G23
                        Nautique needs a flip up panel, similar to NASCAR vehicles that pops up in the back of the rear pass through when ever you rapidly decelerate! But as already mentioned, turning one direction and slowly decelerating prevents the issue. I also back up slightly which pulls the boat back to center and allows you to retrieve the rider without driving through your rollers when you turn around.
                        • DLafont
                          • May 2009
                          • 340
                          • Gatineau Qc
                          Just remember: https://youtu.be/PtXa1a824TY
                          Previous: 1990 Ski Nautique
                          • deelan
                            • Jul 2015
                            • 90
                            • Denton, TX
                            • 2015 SAN 210
                            Originally posted by DLafont
                            Just remember:
                            I Need one of those shovels!
                            • ScooterMcgavin
                              • 1478
                              • 2014 SAN 210 TE
                              Another good use for the shovel.
                              1989 Sport Nautique
