Just bought a 02 SN. I cant get the drain plug loose. There isnt enough room to get anything long enough in there. I let it soak (top and bottom) with PB blaster and still no budging. I found a full replacement (http://www.nautiqueparts.com/drainpl...ndlewbase.aspx). I was thinking of unscrewing the 4 screws at the bottom of the boat and seeing if the whole unit will slide out from underneath. I might have to cut off the T. I can always try just replacing the T handle if the bottom unit stays undamaged.
Anyone ever done this before. Is their any sort of gasket I need to be aware of if I remove the brass base?
