Assisted lift tower
  • OZDreamer
    • Mar 2009
    • 39
    • Australia
    Assisted lift tower
    Hi All,
    I have a 2003 DD Sport 216 with a factory Flight control tower. I need to replace it with something lighter, easier to handle and with assisted lift/lower. Still want to make sure it looks good and not out of place though. I have been looking at the Roswell Aviator. Are there any others that I show consider?
    Wes
  • laddski
    • Aug 2003
    • 110
    • Billings, MT
    Double check the fold down height of the Aviator. I almost went with it and then bailed because it would not fold down low enough to fit in my garage. Really nice tower though. I ended up going with a Samson Edge tower. The fold down is pretty simple and it folds back instead of forward. Here is a video of the tower folding.
    https://www.youtube.com/watch?v=m6S7lNYQmwE
    • simplysanj
      • Jun 2005
      • 133
      • Montreal/St. Donat/Costa Rica
      • 2002 SAN TE Python
      Originally posted by OZDreamer View Post
      Hi All,
      Wes
      If it's just the handling that is a problem for you, it's very easy to take off the tower, insert a spring + steel wire or bungee cords inside the hollow tubes to make it easy for a single person to lower. The newer towers have some kind of spring inside the base pods that work that way.
      From experience, WAY CHEAPER than putting in a new tower.
      Alternately, put one hook or loop bolt on the lower tower and one on the upper and put a strong bungee between them when you want to lower/raise tower. Total cost probably about $25.
      • simplysanj
        • Jun 2005
        • 133
        something like this... Click image for larger version
