Hey guys, I recently bought a 2014 g23. I have been out on it a handful of times and love everything about it! I primarily surf and have a few questions. First, when I fill up the ballast and then go to drain the tanks I don't see where the water is being pumped out? I know its emptying because the wake goes down considerably. My screen shows the ballast tanks empty as well. Maybe I am missing something....Also, I notice the pumps run for about 2 minutes after the screen says their empty. Should I shut them off or let them run until they shut off on their own. I usually use the "back to dock" setting that emptys all the ballast tanks.
The other thing I am considering is adding sacs to the boat. 750's in the rear and not sure yet up front. Is it easy to plumb these bags into the current system? Or am I better off throwing the bilge pump over the edge to manually fill them? How do you guys set yours up and are you capable of filling up the tanks and the sacs off the stock system thats on the boat?
