Help with tow point
  • Shamsra
    • Mar 2020
    • 58
    • Austin, TX ~ Lake Travis
    • 2023 Supra SL Traded in: 2020 Nautique 200
    We abandoned the tubes long ago. There was a steady progression from boredom to injury almost every time we took it out. Besides, your fellow boaters will thank you for not churning up the water and driving like a nutter. Ban the tube!
    • jemcnamara1
      • Jun 2020
      • 5
      • TX
      • 2015 Super Air Nautique G21
      Originally posted by 2001SAN View Post
      Hi Jeff.
      By 'bar' do you mean the grab rail on the transom? I'm not sure that that is a good place to tie a tube to. I can't see there being much support behind that as it is only intended to help you climb onto the swim platform.
      D.
      Yes I think I am, it has a tow hook on the back side of it to tie a rope and there is nothing else on the transom I that I could tie too. I’d share a picture but says I am not allowed from the app I’m using on my phone.
      • Jonny Quest
        • Aug 2014
        • 384
        I would never pull a tube from a ski pylon — too much torque/force. Good way to bend or break things. Tubes today go up to 5 riders. That weight is waaaay more than any ski pylon is designed to take. The lifting ring on the back of my SNOB has a warning decal that says 2 skiers maximum load. I pull my 2 little granddaughters on a medium-sized tube off the lifting ring but that’s all. Nice and slow.
        there are some after-market transom mount tow hooks available, but I would install a significant metal backing plate to spread the load. I would even fiberglass the backing plate to the transom for additional strength.
        While I wholly support the statement: “get the kids out skiing” I also recognize that there are times when a tube is a nice option to have — particularly with the kiddos or when it’s too rough to ski.
        JQ
        • jemcnamara1
          • Jun 2020
          • 5
          • TX
          Thanks folks, as noted by many, we didn't buy the boat for tubing but my kids do like it when they are tired of wakeboarding or have friends with them. Appreciate the responses.
          JMc
          • 2001SAN
            • Apr 2012
            • 203
            • Ireland
            • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
            If there is a hook then you are likely grand. Sounds like it has two purposes. Nice feature on newer boats I guess!
            D.
            • Kenv
              • Jan 2004
              • 1070
              • Texas
              #21
              D.
              Yes...on the 2015 G21 there is a dedicated "T-bar" to hook the rope to just behind the grab handle to get up on the platform. That is the only "Low" tow point on this boat.
              • Infinity
                • Sep 2017
                • 730
                • Lake Norman - Denver, NC
                • 2014 SV244 w/ ZR409
                #22
                jemcnamara1 That bar at the back of the transom is designed to take the stress of pulling a tube. It does limit how much you can "whip' people cause of the rope dragging or catching on the water and will also kick up water spray like you stated. They sell an inflatable "ball" that is designed to be placed approx in the center of the tow rope and it keeps the rope from dragging in the water.
                https://www.amazon.com/SportsStuff-5...NsaWNrPXRydWU=
                • WakeUT
                  • Aug 2019
                  • 64
                  • Utah
                  • '01 SAN 210
                  #23
                  After reading this I’m still not sure if it is better to pull tubes from the tower or ski pylon (2001 SAN)
                  While I don’t like tubes my kids are little. The older 2 will wakeboard when it is nice but the youngest not yet. I don’t pull them fast or try and dump them.
                  • mcosub
                    • Aug 2016
                    • 235
                    • Orlando
                    • 2020 GS22 2017 SANTE 210
                    #24
                    This is what some are talking about. This is the grab handle right above the swim platform. My 210 was like this but my GS 22 doesnt have the T bar to hook ropes to
                    • Kenv
                      • Jan 2004
                      • 1070
                      • Texas
                      #25
                      Yep...that's it. T-Bar stands for "Tube Bar".....LOL....
                      • Rbt
                        • Feb 2019
                        • 24
                        • Utah
                        • 2018 G23
                        #26
                        I don’t know how your tower is constructed but I’d probably pull from the tower. Small kids going slow put very little strain on it. Plus it keeps the rope out of the water so it’s not splashing them.
                        • 2001SAN
                          • Apr 2012
                          • 203
                          • Ireland
                          #27
                          Not that we tube much, in fact not at all anymore, but we have always towed from the ski pylon on a 2001 SAN. Over the years I have seen many boats pull tubes from the ski pylon with no issues. Back in our early days a friend would pull tubes using a Ski Centurion Barefoot Warrior to the point of tube and rider destruction with no issues on the ski pylon (at speeds I will not mention). Disclaimer: not safe but we had waaaay less sense back then.
                          However, with a slow and careful tow with kiddies I am sure you would be fine from the tower.
                          D.
                          • Gtsum2
                            • Jul 2019
                            • 224
                            • Virginia
                            • 2020 G23
                            #28
                            If the tower can’t take the stress of pulling a couple of kids weighing 200lbs total, how In the world can it take the stress of bigger, professional wakeboarders cutting as hard as they do? I pull tube for the kids from the tower. If my power actuated tower breaks from that, think I’ll be looking for a different boat
                            Sent from my iPhone using Tapatalk Pro
                            • WakeUT
                              • Aug 2019
                              • 64
                              • Utah
                              • '01 SAN 210
                              #29
                              I’ll probably keep pulling from the tower. My wife tells me she can feel me pull the boat when I cut on the wakeboard, I don’t feel the kids doing that on the tubes.
                              • SkiTower
                                • 2172
                                • Clayton, NC
                                #30
                                For the OP, keep it to a 1-2 person tube with kids and you should be fine with the tower. If you’re actually skiing, though, adding the ski pylon would be a nice addition and flatten out the wake a little. For those arguing about tube vs ski or wakeboard, the extreme loads on a tube come from either the tube submerging or trying to pull the really big ones. If you got a really big one AND submerged, that will damage you boat.
                                2007 SV211 SE
                                Tow Vehicle 2019 Tundra
                                Dealer: www.Whitelake.com
