Those that keep the weight in their G, how much? Is 400 lbs in the nose a number that can stay all the time. Does it make much difference to the surf wake?
A d m i n i s t r a t o r
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
I usually run about 1,000 pounds over stock, but it is spread fairly evenly front-to-back. Why so much just in the front?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I ran 400# of lead in the nose all season and loved the surf wake. Surf waves are subjective but I think you're on the right path. When you buy the bags they are easy to move around so adjustments are easy to make.2015 G23 550
2013 Malibu 22MXZ
I put my lead under the helm, and in the observer storage. I had to remove the starboard bow seatback, and slide the pocket door assy a little bit. Dropped the lead in from there and push it towards the back. Then remove the stainless plate under the helm seat, reach in there, and slide the lead under the helm seat.
That said, I set my boat up with a seperate integrated ballast system that fills 600lb bags under the lounge area seats. I don't add anything in the rear compartments. If I did, I would need the lead further forward. The key with the G (that I have found) for surfing, is to have the center of gravity right below the tower legs. When you add ballast, try to imagine that the boat is balancing on that point of the hull. When it is full, you want the weight to balance at that center point.
The nice thing about having the lead under the helm and under the observer seat, is that it handles a lot better empty, compared to having a bunch of weight all the way up in the bow. The downside, is that if you fill bags in the back compartments (instead of a more centralized spot), the lead won't be far enough forward to balance the boat correctly.
When wakeboarding, I don't fill the bags. The wake is already too big for my skill level. Having the lead more central allows me to do this without screwing up the wake because the added weight is too far forward.
Also, on a 2016, you will automatically want to put 150-200lbs of lead under the observer seat, and then add evenly after that. The '16s need about 200lbs extra on the port side in order to balance side to side (with equal side to side passenger weight). Not sure if the earlier boats are like this, but wouldn't be surprised if they are. Quite a bit of extra equipment on the helm side of the boat.
- Oct 2014
- 563
- Radford VA
- 2016 Nautique G23. Masters Blue/Gunmetal Flake
Originally posted by markj View Post
Do you trailer with that 1000lbs too or load it in and out every time?
Pretty sure Jeff tows it with this extra 1000lbs left in it based on his thread here: http://www.planetnautique.com/vb5/fo...ries-nautiques
But even if he didn't want to tow with it in the boat, he would still have to put it in the bed/back of his vehicle (which would be harder on the vehicle than leaving it in the boat). Unless he had somebody driving a second vehicle just to haul the lead weight. Just a thought.
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
Yep, that's correct. I put it in when I get the boat, and take it out when I sell it.
Where is the best place to put the lead to balance the boat port to starboard? I love my G but one of my few complaints is that the boat does not run level empty and I have to compensate for the starboard lean when filling my ballasts. Will 200 lbs of lead on the port side fix it? Where is the best place to get the lead?
- Oct 2014
- 1026
- St. George, Utah
- Red Metal Flake 2016 G23! Malibu 25 LSV 2019 2021 Centurion Ri237
Originally posted by pmellis View PostWhere is the best place to put the lead to balance the boat port to starboard? I love my G but one of my few complaints is that the boat does not run level empty and I have to compensate for the starboard lean when filling my ballasts. Will 200 lbs of lead on the port side fix it? Where is the best place to get the lead?
There are lots of places to get lead. You can get it ghetto style by going to your local shooting range and getting the spent bullets. Or you can get the used pieces from a local tire shop. You can then put them in a 4 inch piece of PVC pipe that you cap off and it will weigh a good 50 pounds depending on how long you make it. Fashion some straps around the PVC to allow you to be able to pick it up and move it around. Several of those will fix the balancing issue.
Or you can buy it for more than a buck a pound at a place like pop products or lead wake.
My plan is to add another battery or two for the stereo and tuck them under the port side bench. Then at least the weight serves some useful purpose. I have found that if I have 2 passengers and just 1 driver, the boat is pretty well balanced out. So 200 pounds might seem a bit too much unless you are in a state where you have a driver and no observer.
On my 15 G23 250 lbs in the low spot under the observer seat is perfect, for just the driver only.
We ended up moving 100 lb to the driver side. This was because with others in the boat we ended up with too many people piled up on the starboard side to keep it level.
In order to not move the lead and risk dropping/damage to the boat we got a Fly High brick. When it's just the driver fill it up in the cabin all the way against the port bench. Then once underway with a rider the driver can pull it to starboard as needed while driving without getting up. This is assuming your driver isn't a midget or small woman.
