It looks like I'm finally going to upgrade from my '99 SN to a used 200. My lake is at 6900 ft so I definitely will be getting one with the ZR409. What would be the best prop for the 200 at that altitude. We usually use it in our course which is 2200 ft long. I tow some pretty big dudes and need the ability to pull at 36 MPH, but usually will be skiing from 28-34 MPH depending on who is behind the boat. I don't barefoot but would like to still get 40 MPH because I have a neighbor I occasionally will pull.
I thought maybe the original 1868 prop would be good because it turned about 450 RPMs more than a 422 (which seems to be a sea-level standard for the 6.0's). Is there another option that might work better? I need to make-up for the 20% HP decrease on the holeshot but would prefer not be turning super high RPMs at 34 MPH where it will be super loud in the cockpit. Could I recup an 1868 so it turns less at higher speeds?
Also, did Nautique change the insulation in the motor box between 2010 and 2013? I have read stories of the 2010's being loud but wasn't sure if they fixed this via a re-prop, motor insulation or both. Any significant changes between the years? I know the 2010s had Linc 1.0, and in 2013 I believe they integrated the ZO into the Linc 2.0. Other than that I haven't seen much change until 2016 with the new seats and motor options. I'm not worried about minor things such as change in radio manufacturers, battery chargers, etc.
Thanks in advance for any info you can give me. I know this site is mainly discusses wakeboarding/surfing boats and issues but I figure there are still a few 200 owners here.
-Marc
