So I am about to order bags and the plumbing to install on my boat. I am trying to save some coin here and this was my idea and was curious if anybody else has installed theres like this. I want to put in a "Y" valve off of the existing pumps for the rear bags. I was thinking I could just fill the aftermarket bags first and once they were full I could switch the valve to the stock bags. I figured I would have to do it this way so the system doesn't know if the stock bags are full or not which would in turn automatically cut off the pumps. Then when I fill up the stock bags the system will work as normal. I know this will take longer to fill my boat up with ballast but I don't feel like drilling holes in my boat or throwing pumps over the side as well. Up front I am going to use lead. What do you guys think?
Should work fine. The order of filling won't matter though. The factory pumps will run whether the stock ballast is full or not. You'll have to install a Y in the vent line as well though, and you might want a check valve in there so the overflow from one won't flow into the other.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
