Hey guys just bought a 2013 G23 from Minnesota but up in Northern Alberta Canada. Zero off gps worked fine when we were down in Minnesota but now in Alberta the gps won't keep a signal, it worked for a couple minutes at a time but mostly couldn't get any signal while out on the water today. Sky didn't have a cloud in it. Any thoughts as to why this could happening? Does it need to be recalibrate for a new area? Where are the anntenaes for the gps? Any ideas at all are appreciated I don't have a clue. Thanks
the antenna is starboard side in front of wind shield , just a persons arm on it will effect it or a towel .....do you remember if any one was sitting up front that might have interfered with the little black puck???2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
Originally posted by robertsmcfarland View Postthe antenna is starboard side in front of wind shield , just a persons arm on it will effect it or a towel .....do you remember if any one was sitting up front that might have interfered with the little black puck???
Alittle update, I pulled the bow seat back off and the plug was intact. It has 4 wires coming out a red gps, black gps and a twisted pair can bus hi and can bus low. Any idea what the voltage readings should be on the can bus? I think it's a faulty gps puck but I just want to be sure.
