Originally posted by ScooterMcgavin
View Post
That does look a little longer, smaller but longer. How about moving that lead from port corner to port bench? We put a 400 sac in the port locker yesterday and tried moving people up front to see. But the wave didn't get much longer, it was definitely better with the sac in the port bench, but we have seen longer waves out there so still trying to dial it in.2009 Super Air Nautique 210 TE
1989 Sport Nautique
These shots are taken from the same weight set-up, same speed, just different NCRS and NSS settings. One mellow, easy learning wave and one nice steeper wave with a great lip for boosting airs.
Full Port, 3/4 Starboard, Speed at 11.1. No belly weight (or very little, one rider in the bow). NCRS and NSS anywhere from 1-3 to get the perfect wave. Super long, super clean with a hard lip.
I haven't seen any benefit for size and length of wave from running full on everything and adding additional. Just burns more gas. Maybe it gets steeper but it seems like I can make the wave too steep with NCRS and NSS with my weight settings.
Originally posted by F725 View PostThese shots are taken from the same weight set-up, same speed, just different NCRS and NSS settings. One mellow, easy learning wave and one nice steeper wave with a great lip for boosting airs.
brookdaddy, I've adjusted NCRS and NSS depending on rider ability and quantity of people in the boat so I've yet to really settle on one setting but I guess that's one of the biggest benefits of NSS and NCRS anyway.
According to the pro wakesurfer that gave me the weighting suggestion... he said he adjust the settings until the wash and the peak of the wave meet to form a defining edge or lip. Tough to explain in words I guess.
But I've been getting a steep wave for our surfer crowd by bringing the NCRS up to 3 or 4 and NSS up to 3. Anything higher on the port wave and it shortened up too much but at those settings it was much steeper than I like to ride. For the surf style guys I've also bumped up the speed another click or two and that'll bring some length back.
I currently run my boat (2014 G21) with full stock ballast and have extra 500lb sacks in each of the rear lockers for my starboard setup. For the port side I transfer the 500lb sack from the starboard side to the port side locker (1000lbs). This seems to work extremely well and am left to wonder if I should go even bigger.
Speed seems optimal at 11.1 - 11.3 with NCRS & NSS at 3-4.
I've tried extra weight in the bow but it's been my experience that my G don't like it.
Waderson, your set up may work well. I haven't tried adding the extra weight with water but have had guys move around the boat to imitate the extra ballast. I haven't been successful but maybe I didn't experiment enough. Next time you're out, see what the difference is between your set-up and just using rear (heavier on the port side for both waves seems like it works). I'm interested to hear more results and favorite set-ups.
This photo was taken from the back of our boat level with the walk thru. (a bit of a crafty camera angle but the wave is pretty big none the less).
I have a 2016 G21 and I put 280# in the port rear locker and 120# in the port bow and it really cleaned up the port wake. NSS 0, NCRS 3, 11.6 MPH and all ballast at 100%. When I wakeboard I run 50% in the port ballast and and the others full and the wake is even and great. Still playing with starboard surf wake it looks like 50-70% full on the port ballast will give the best wake.
