Oil Filter
  • 4th ski-doo
    • Apr 2013
    • 307
    • Wilmington
    • 2013 SANTE210 2011 Sport200V 1994 Bimini Skier 190 1986 Master Craft Pro Star 190
    Oil Filter
    Will a Motorcraft FL1A replace the PCM RO77001?
    2013 SANTE 210
    2011 Sport 200 V
    1994 Bimini Skier Pro 190
  • rossrips7
    • Feb 2010
    • 233
    If it's a gt 40 the fl1a is the right filter I know. There are also numerous other brands that will work the ford filter is definitely most common.
    • Quinner
      • 2246
      • Correct Crafts
      FL1A is what the remote filter on my Chevy PCM uses.
      • 4th ski-doo
        • Apr 2013
        • 307
        • Wilmington
        Thank you Quinner, I had heard that but wasn't sure. The PCM is only $10 on line but just in case I forget it when I go to the cottage I know the Motorcraft is everywhere.
        Rossrips7, thanks fir the answer but it's a GM with the remote filter. PCM only lists 1 filter so I was guessing there's an easier replacement.
        I'm doing impellers, separator and fuel filters but think I should've done it last year.
        2013 SANTE 210
        2011 Sport 200 V
        • Quinner
          • 2246
          • Correct Crafts
          You probably know this but do be careful when changing oil filters, the old rubber gaskets have a tendency to not come off with the old filter, so always check the mating surface before installing the new filter.
