Bad ballast sensor G series
  • trip33
    • Nov 2010
    • 248
    • Odessa, FL
    Lately the LINC always says my port bag is full when I power up the boat. The pump fills and empties fine and the boat is on a lift so I know it is empty. Unplugged the ballast sensor, replaced the 1 amp fuse, cycled the power, same result. Bad sensor? Anyone else had similar issues?
  • robertsmcfarland
    • Oct 2004
    • 544
    • Hyco
    • 2014 g23 550
    I replaced mine under warranty and work fine after false readings
    2013 G23 super air
    2010 230 super air
    2009 220 super air
    2008 210 super air
    2005 210 super air
    2003 calabria pro air
    • Zicer
      • Jun 2016
      • 3
      • OKC
      • 2013 Nautique G23
      I am having the exact same issue on my 2013 G23. Every time I power the boat on, the Port ballast shows full. Works and reads just fine once you let the pump run on drain for a few minutes. Interested to see if we can get any DIY help that doesn't require taking it to the dealership. Thanks
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        Wilson Watersports? Lol
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2011 Malibu Wakesetter 247
        2007 Yamaha AR210
