Shower pump wiring
  • richard
    • Feb 2005
    • 406
    • HK
    Shower pump wiring
    I'm appreciate if any body will tell me where exactly the wire for connecting shower pumps +12V since there are"shower " botton on ther dash,I want the show pump control by it but can't find where. I had download the 2001 SUPER AIR NATIQUE wire diagram,but that don't match.
  • MHayes
    • Aug 2004
    • 830
    • Roswell, GA
    RE: Shower pump wiring
    richard, there should be 2 wires coming off the back of the switch for the shower, one coming from the power source and the other which would connect to the shower pump.
    2001 Air Nautique
    • richard
      • Feb 2005
      • 406
      • HK
      Good morning, Mhayes:
      I look the wires in engine room since I thought it sould be arrange to there,my boat is 2001 is 2001 SUPER AIR NAUTIQUE, the botton is electronic touch botton. I had several time open the dash,but don't see such connection, may be I should check more time if you can find there,
      Thank for your input.
      • MHayes
        • Aug 2004
        • 830
        • Roswell, GA
        Not sure if the wiring is consistent, but in my 2001 Air owners manual it shows the shower as being an orange/black wire. You might check your manual in the Engine Maintenance chapter.
        2001 Air Nautique
        • richard
          • Feb 2005
          • 406
          • HK
          Shower pump wiring
          I serveral time to find this color cable according to the wiring diagram also,but can't find.
