problems with 206 on a Prestige trailer
  • gatorgates
    • Aug 2003
    • 112
    • Springfield, IL
    My 2003 ski 206 came on a prestige trailer. This trailer has a roller on the front post instead of the vee post and it is driving me nuts. When I load the boat out of the (very) shallow pond with the (fairly) steep ramp, the front of the boat actually hits underneath the roller. I have to either get three heavy guys to sit on the back or three strong guys to lift up on the bow to get it to sit correctly. When I don't have access to that kind of help, I unhitch the trailer and sit it on ramp (leaving the chains attached) and then load. I tried a lower hitch, but to get it low enough it hits when I go over uneven pavement.
    Anybody else had this problem? Prestige has been understanding but wants me to tug the boat down to their factory before they can come up with a solution. Thought I'd try you guys before making the 4 hour drive.
  • skinautique
    • 1749
    • Colorado
    how far are you backing the trailer in? Sometimes if you back it in too far, it won't want to sit right. Both fenders should be up out of the water. You can also back it in too deep to wet the bunks and then pull out so that the fenders are out again. See if that helps out. Also, you might need to adjust the front roller. Do you have the v bunks up in the front?
    • gatorgates
      • Aug 2003
      • 112
      • Springfield, IL
      Thanks for the reply. I doubt that I am backing in too far. The rear of the trailer jams into the mud before I get that far. We are talking about between 3 and 4 foot of water. In our public lake, with deeper water, everything works fine. I am not completely sure what you mean by "v bunks" but I am attaching the best picture that I currently have of the boat on the trailer. Maybe that will tell you something.
      • skinautique
        • 1749
        • Colorado
        Yeah I can't tell for sure but if you look on the front of the trailer, some of them have a "V" right in the front where the bow comes up into. Your best bet might be to try adjusting the bow stop and lower it if you can so that you don't go underneath. Hope that helps. Keep posting and I will see if I can save you a trip to Prestige. What does your dealer have to say about it?
        • M3Fan
          • 1034
          gator-
          This problem is almost always caused by the trailer being backed in too far. If you think about it, when the boat is sliding forward on the bunks, it has to be at the right height for the roller, by simple physics. The act of the bunks being in contact with the boat guarantees that the boat is at a constant height relative to the roller because it is sitting on a static object. If the trailer is lower than the boat, and the boat is floating on the water, the nose will be below the roller. Try it with the trailer out even further, wetting the bunks first. Could be that the ramp is at a bad angle, so your pulling the trailer out even further may look exaggerated but will compensate for the angle.
          That is a nice rig, by the way.
          2000 Ski Nautique GT-40
          2016 SN 200 H5
          www.Fifteenoff.com
          • tryan
            • Nov 2003
            • 267
            • gatlinburg tn
            i have to agree with m, but try this. dive to the 'pond' with your normal reciever and then swap out when you need to pull the boat out. once you have recovered the boat and get on level ground, swap the recievers again. they do make recievers that are height adjustable.
            i would also try to not back in as far and see what happens. (the ramp angle is critical for me also.) 6" makes a big difference. i have the v pad, but i have to leave the turnbuckle loose when i recover. there is a big hill leaving the lake that i scoot the boat up on the trailer with a quick jab of the brakes. then i stop and tighten everything up.
            red right return
            • MinnesotaNautique
              • Jan 2004
              • 207
              I have a 2003 206 w/prestige trailer too, and have nothing but problems with it. The trailer in my mind is entirely worth-less, and never goes on straight no matter how great the launch is or the depth of the trailer.
              • Luke
                • Mar 2003
                • 509
                • Des Moines, Iowa
                I have a 2003 Prestige trailer also, I've had tons of problems with it before. I have lots of problems with loading but usually it's all a matter of how far the trailer is in the water.
                • tryan
                  • Nov 2003
                  • 267
                  • gatlinburg tn
                  when i bought the '72 separator from my brother he told me that the trailer must be perfectly level durring loading or you could forget it. i practiced at a lonley ramp for a year before i would retrieve the boat in public ( read waiting line). he was correct.
                  i'm not telling anybody what to do, but if I have the top of BOTH fenderwells at the waterline (this is level) loading is a breeze. you might have to jacknife the truck and trailer on a crooked ramp and look stupid, but it works. i actually tell everyone to get out of the boat before i load, because i just hate it when someone moves from one side of the boat to the other. I HATE THAT.
                  if you are into deep, there is no telling where the boat will be when you pull out. not backing in far enough will put to much strain on the boat when you load.
                  the prestige looks the same as my 89 cc drive on /float on trailer. it's disgustingly familiar.
                  red right return
                  • skinautique
                    • 1749
                    • Colorado
                    Prestige was very anxious to break away from the standard A-Frame with the bow stop. Once they had their chance, they broke away. In my mind, they screwed because if it isn't broke, don't try to fix it!
                    • Onthewater
                      • 695
                      • Near the cheddar curtain
                      off topic, tryan...nice avatar :P
                      I don\'t care.
                      • tryan
                        • Nov 2003
                        • 267
                        • gatlinburg tn
                        Yup. poor james got busted again.
                        red right return
                        • Hollywood
                          • Sep 2003
                          • 1930
                          • WIIL
                          When can we expect Ms. Chernobyl?
                          • lcap
                            • Nov 2003
                            • 192
                            Perhaps CC could start to actually work with ONE trailer manufacturer who will a trailer to CC's specfications that will work for their customers boats!
                            My dealer tells me the keel roller on the DHM will probably have to be switched out for carpet (back to the *#*)(@! the gelcoat) because of the problem just discussed and on a steep ramp (like mine) the boat rolling back off the trailer.
                            • skinautique
                              • 1749
                              • Colorado
                              Ram-Lin is the company that CC directly deals with. The two companies work very close together. One of the main reasons that dealers offer these other brands is to cut the price down for the customer. Any dealer should be willing to order a Ram-Lin trailer. I keep crossing my fingers that they will start to make their own trailers again once they move in the new factory. I know they don't have enough room right now.
