Do you add extra ballast to surf your G23?
  • Whitetail15
    • Apr 2010
    • 603
    • 2016 G23 H6
    nyryan- what make are those y valves?
    2016 G23
    • nyryan2001
      • Mar 2013
      • 1993
      • Lake Anna
      I donno Brother... Call Mike or Colston at Buxton and ask? Whatever they are using for their G Y valve 1100 setup.
      2019 G23 450
      2014 G23 550
      2013 G23 450
      2011 Malibu Wakesetter 247
      2007 Yamaha AR210
      • sgresham
        • Aug 2016
        • 33
        • Argyle, TX
        • 2016 SAN G25
        My setup is just like that, except 750s
        • sgresham
          • Aug 2016
          • 33
          • Argyle, TX
          • 2016 SAN G25
          Originally posted by Hogwild View Post
          For me the 3 setting seems to make the wave the steeper without being too steep, but I'm not going as fast as you. I'm gonna play with it some friday and try your settings, are you running with both extra locker sacs full?
          both full for me
          • bblueg
            • Jul 2012
            • 158
            • Higgins Lake, MI
            http://www.forespar.com/products/boa...onnector.shtml
            2013 SAN G23 450
            • Beg4wake
              • Oct 2014
              • 563
              • Radford VA
              #21
              I only added 200#'s lead to the port side to help wit prop torque! The stock wave is good enough for me. however, I would like to try out Drew Daniello's set up for my skim style board. He only adds a couple hundred pounds or so up front to get the nose down some to lengthen the wave out. However the stock ballast is fine for my surf style board!
              • gmustangt
                • Aug 2015
                • 25
                • Kelowna BC
                • 17 g23
                #22
                Does buxton relocate the pump?
                oem engine dividers hold up unreinforced?
                • Tallredrider
                  • Oct 2014
                  • 1026
                  • St. George, Utah
                  #23
                  The pump stays in the same place.
                  I am pretty sure that the dividers hold up just fine, but I am worried about the 1100 pound sacks in there as well. Hopefully Ryan will chime in about 1100 in there. I am sure 750's would do just great.
                  • nyryan2001
                    • Mar 2013
                    • 1993
                    • Lake Anna
                    #24
                    Maybe slight bending of the panels when full?? They've never jumped tracks and look new. No issues.
                    and yes a slight relocation of the pumps to crag a little room for those valves.
                    2019 G23 450
                    2014 G23 550
                    2013 G23 450
                    2007 Yamaha AR210
                    • sgresham
                      • Aug 2016
                      • 33
                      • Argyle, TX
                      • 2016 SAN G25
                      #25
                      I'm kinda wanting to add some lead up front to lengthen the wave as well. nyryan also has me wanting to change the 750s out for 1100s. There can't ever be enough, can there? I know most of the pros bag the crap out of their tow boats.
                      • MJB
                        • Jun 2006
                        • 229
                        • Jacksonville, Florida
                        • 2014 G23 Coastal Previous Boat: 2011 Team 230
                        #26
                        Stock ballast full and 1000# custom G series sacs from wake makers in each locker (3/4 full) and fly high / fat sac piggy back under the bow seats
                        • Neverenough
                          • Sep 2012
                          • 907
                          • Ft. Worth Texas
                          • G
                          #27
                          Still no video or pic?? Must be a myth!
                          • Hogwild
                            • Aug 2013
                            • 42
                            • Louisiana
                            • 2020 P25
                            #28
                            Originally posted by sgresham View Post
                            I still run 5 and 0, but I will try 5 and 3. Did that lengthen the wave some?
                            I played around with it some this weekend, the wave definitely got much longer at 11.7-12 but seemed to lose some steepness right behind the boat.....we ended up running stock ballast full, port side locker sac full, starboard side locker 3/4 full (found this to balance/level the boat out) at 11.5mph and anywhere from 6-8 people on board....wave was as good as I've ever had it.
                            • sgresham
                              • Aug 2016
                              • 33
                              • Argyle, TX
                              • 2016 SAN G25
                              #29
                              Here's a short video of my G25 wave with 750s in the rear.
                              https://vimeo.com/182795488
                              • nohlan_4
                                • Jan 2016
                                • 418
                                • Canada
                                • 2013 G23 450
                                #30
                                I had to reinforce my dividers. They would jump tracks and bend a lot with the 1100's completely full.
