Advice for new '14 230 owner
  • Bender594
    • Sep 2016
    • 3
    • Lexington KY
    • 2014 230
    Hey all. So, just bought my first Nautique, a 2014 230 with 244 hours. I would appreciate any advice as to what maintenance issues to expect with these hours as well as tips for preventative maintenance that aren't otherwise obvious (owned boats for 30+ years, just first Nautique, so I have the basics covered). Basically, if you have any insider/been there, done that/experience based advice, I would greatly appreciate it. Thanks in advance for your response.
    FYI, last boat was '09 Tige' 24 Ve, so I have a little experience with the type boat, just not this boat.
    Again, thank you.
  • Guntersville230
    • Aug 2015
    • 419
    • Guntersville, AL
    • 2015 SAN 230
    Have a '15 230 here with the 343 and all is good so far....these boats (nautiques) are great boats! Question may be what sports are u interested in and how to maximize the 230 to your needs/wants?
    Sent from my SM-G935V using PLANETNAUTIQUE mobile app
    • Neverenough
      • Sep 2012
      • 907
      • Ft. Worth Texas
      • G
      Add water and have fun, change oil, add more water and have fun...... We have a 230 w 270 hours now and have had zero issues. 343 power and surf a lot.
      • Jeff88
        • Oct 2015
        • 82
        • Indy
        • 2014 SAN 230
        Add 750s in the back and shore up your engine dividers and surf away!!
        • Bender594
          • Sep 2016
          • 3
          • Lexington KY
          • 2014 230
          Well, sounds good, little oil, water and weight should be doable. Looks like there are plenty of suggestions on shoring up the engine comp. dividers so pretty small winter todo list. That's a good thing . . .
          • lucky7t
            • Mar 2011
            • 1306
            • Oklahoma
            • 2015 SANTE
            Make sure the impeller is changed
            Sent from my iPad using PLANETNAUTIQUE mobile app
            Current Correct Craft Boat
            Correct Craft Boats Owned
