Depth finder, transducer glue on inside or through transom
  • jos
    • 154
    • Netherlands Boxtel
    Hi there,
    We wolud like to have a depth finder Humminbird HDR610 as it looks,
    Option, transducer glue on the inside signal through the fiberglass is atractive because of easy install. Is this working well?
    Option mount through hull isnt my favorite, drilling is easily done but pierces my heart also.
    Option transom mount does look cheap to me.
    Anyone mounted this as an accesoire. Whats your experience.
    Pucktransducer also angled type??? Both glued on inside XP920&T... and XAP920. Wherefore angled???
    Thanks for your help.
  • brianc
    • Dec 2004
    • 46
    • Europe
    • 1999 196 2005 196 team zr6 2005 226 team zr6 2007 211 team zr6 2006 196 excal 2008 196 limited z409 2010 200 team ob 343
    IVE BEEN TOLD THE TRAMSOM ONES DONT WORK THAT WELL ON SKI BOATS I FITTED ONE TO MY OLD BOAT AND HAD TO GLUE IT TO THE INSIDE OF THE HULL AND IT WORKED FINE APPARENTLY THEY ARE THE SAME UNITS SO I WOUNLD PAY EXTRA FOR A SPECIAL ONE ????? MINE WAS A STERN MOUNTED AND IT WAS FINE
    • Fredk
      • Jan 2006
      • 34
      • No. Nevada
      Depthfinder mounting
      You might checkout this thread and the ones within it. Not high on Hummingbird as they are real inconsistant with their readings. As far as mounting ... I suggest glue and shoot thru the fiberglass. It works well with a good unit.
      http://www.planetnautique.com/index....ewtopic&t=5330
      Good Luck!
      • jos
        • 154
        Brand
        I also looked for Faria,
        the gauge looks exactly the same as Faria,
        a quick look the faria is doble the price on a Humminb overhere.
        • Fredk
          • Jan 2006
          • 34
          • No. Nevada
          RE: Brand
          They are much more over here also, but what is the cost of a new prop or having to have it reshaped, a bent shaft, rudder, etc. My point is, if you are buying it for protection of your boat while running in shallow water and/or into obsticles and doing damage to it, wouldn't it make since to spend the extra $100 or $200 on a more reliable unit to save 1000's?
          • jos
            • 154
            Protection
            Protection, that makes sense. okay thats clear to me.
            Because theirs a lot of talking about this device it isnt easy to conclude what OK.
            My idea do it right the first time, ment is the mounting option, glue on, through or transom mounting.
            I wont get a good look on this after al the forum talking about this subject.
            The glue on inside device comes in a puck and angled puck, Hummbird documentiation doesnt clear which one when to take
            The glue on looks the most easy cable could be skotr to the dash. Is it easy to unglue when the location isnt optimal.
            Whats the standard position whem factory mounted.
            • Miljack
              • Dec 2004
              • 1616
              • Charlotte, NC
              • '08 230 TE ZR6
              Jos,
              I used the "glue-on" straight puck and mounted it under the transmission on our Pro Air. It worked ok last year. This year it's not working! I need to get in there and check all of the connections so I can't comment on the quality of the Humminbird units. I have the HDR600.
              When I checked the inboat unit against a real depth measurement, I was about 2 feet "shallower" on the inboat vs. actual.
              hope this is helpful.
              Jack
              2008 230 TE-ZR6
              • nch20skier
                • 167
                • North Carolina
                I installed the glue/epoxy version on my '83 and it worked fine after the depth adjustment. I did use the puck type. Purchased the unit through discount inboard marine. It took me about 1 hour to complete the installation. Oh yes this was the Hummingbird unit.
                88 Barefoot Nautique
                05 206 Team
