Announcement
No announcement yet.
Winter boat upgrade progress thread: 2016/2017
  • #31
    First shot - looking straight down at the install - one screw hole didn't line up perfectly, and I had the screws out to diagnose my fuel gauge issue.
    I'm quite happy with this little idea that I had - I had a custom cover made for the engine hatch bracket so that it would stop burning my butt when i put my boat on. The two pieces appear ripped, but it was my own fault and they tore a bit when i peeled the backing off. The other looks torn because I didn't learn my lesson on the first one... I then had to 'tri
    If you ignore the mess, you can see that the AquaMarine Deck went in quite well. I'll be posting a full review on my process with them (which was quite smooth) and what it all looks like once a bit cleaner. I also still have to do the swim platform, which is a bit difficult!
    Sent from my iPhone using Tapatalk Pro
    • #32
      Okay finally got to taking some pictures of the progress putting the SS back together as a SAN. first pic is of a shelf I built for the ballast pumps. I also mounted a battery switch to the front, a yandina c100 charging relay to the back, and my hydrophase throttle control motor.
      Next are a few shots of the hatch latch and gas struts/supports I converted to from the old power strut.
      A few shots of the engine dividers and supports
      And the spot I decided to mount the shower mixing valve since there was already a hole there.
      • #33
        Before and after.
        Click image for larger version  Name:	before.jpg Views:	1 Size:	240.1 KB ID:	515853
        Still needs a few hours of work to finish up.
        But aside from the flooring the upgrade list includes:
        Fresh Air Exhaust
        Rudder repack
        New Rudder cable
        General Cleaning
        Cut and Polish
