Water getting in bilge by way of rear lift ring
  • evanrude
    • Aug 2014
    • 87
    • Dayton, Ohio
    • 2009 210 2015 210 2006 220
    When we are out surfing and then stop the boat, we sometime have water wash up on the rear lift ring. See attached pic. The water doesn't wash all the way up in the boat just up to that spot where the lifting ring is. The water then will leaks into the bilge. Does anyone else have this problem? What have you done to fix it?
    Click image for larger version  Name:	lr.png Views:	1 Size:	48.6 KB ID:	506584
  • Quinner
    • Apr 2004
    • 2245
    • Unknown
    • Correct Crafts
    2015 Should be under warranty if you bought new, let the dealer fix it!
    If not, I would remove the ring and any associated trim, remove any old sealant, clean up and then apply a new bead of 3M 4200 sealant as necessary.
    • charlesml3
      • Jan 2008
      • 2453
      • Lake Gaston, NC
      • 2022 G23
      Are you sure it's coming in through that ring and not the vent above? I suppose you could get a leak through the ring location, but I would think it would be a tiny amount and you'd never notice. Far more likely it's coming through that vent. My brothers boat gets water coming in that way.
      -Charles
      • NautiUT
        • Mar 2009
        • 67
        Does it come in when surfing either side or just one side? I would check the transom rub rail corners as well.
        • evanrude
          • Aug 2014
          • 87
          • Dayton, Ohio
          the lift ring is recessed. You pull it up when you need to use it and it is not sealed. you can take a cup of water and cup of water and pour it on that area and it goes straight into the bilge. Its not alot at all. Just annoying and wondered if others had noticed. and if so, what they did to stop it
          • charlesml3
            • Jan 2008
            • 2453
            • Lake Gaston, NC
            • 2022 G23
            Honestly, just ignore it. You're trailering the boat so you have ample opportunity to get water out of the bilge on the way home. Just leave the plugs out driving home.
            -Charles
            • ski4evr
              • May 2010
              • 613
              • Bowling Green, KY
              • 2005 SV 211
              If you never lift it, you could get a piece of seadek to cover it if it is bothering you.
              2005 SV-211
              • Outdoorjp
                • Jul 2016
                • 178
                • Carlsbad
                • 2011 SAN team 210
                I made a machined billet cap for mine that has a o-ring on it.
                my 210 was same as yours.
                • Outdoorjp
                  • Jul 2016
                  • 178
                  • Carlsbad
                  • 2011 SAN team 210
                  If you cannot find one pm me I'll make you one if you get me exact #'s
                  • swatguy
                    • 1631
                    • Midwest/ Northern IL
                    • 2008 SANTE 210
                    Outdoor jeep nailed it. Was going to say try and fabricate some
                    sort of cap with a gasket
                    • Bevostein
                      • Jun 2008
                      • 521
                      • Frisco, TX
                      That's neat but it looks like a real toe stubber or tripping hazard after a couple of cold ones.
                      • Outdoorjp
                        • Jul 2016
                        • 178
                        • Carlsbad
                        • 2011 SAN team 210
                        Are boat is a coastal edition , so I did not want any salt water inside.
                        it does not stick up enough to stub a toe or even notice.
