PCM H5DI 5.3l
  • jjackkrash
    • May 2007
    • 498
    • PacNW
    • 2021 Ski
    PCM H5DI 5.3l
    I am 95% on buying a 200 with the PCM H5DI 5.3l in the next day or two. I have pretty much talked myself out of needing the 6.2, despite consciously and subconsciously wanting redonkulous power on tap.
    All that said, any owners have anything good, bad, or indifferent to say about this engine? Personal experiences to share? The reports I have seen say its a direct replacement for the 6.0l, with maybe snappier bottom end and less top end.
    Thanks in advance.
  • Sailfun
    • Dec 2016
    • 131
    • Lake Norman NC
    • 2018 Nautique G23 2022 Robalo 226
    I demo'd a 2016 G23 with the 5.3 and it did surprisingly well even with full ballast and 4 people. I would think that engine would be a great match for the 200. Keep in mind that in the past engines were rated differently. If the old 350hp 5.7 liter is rated as engines now are it was a 295 to 300 horse engine verses 355 in the 5.3.
    • bandit628
      • Sep 2016
      • 318
      • Southern Illinois
      • Current-2012 SANTE 210 Past Boats 2000 Mastercraft
      I have the 5.3 liter in my 2015 Chevy does great. I realize auto is different than marine, but from what I have heard it is great in a boat as well.
      • jjackkrash
        • May 2007
        • 498
        • PacNW
        • 2021 Ski
        I am just curious, PCM has been rating the 5.7 as 343HP for as long as I can remember, when did the rating system change?
        • Quinner
          • 2246
          • Correct Crafts
          Curious as well, what changed with the HP rating system??
          Jack, the 5.7 Excal was initially 330hp when introduced in 2002, in 2008 PCM did some tuning/software changes which increased the HP to 343.
          • Evening Shade
            • Apr 2015
            • 1295
            I think what Sailfun is referring to is the old way that horsepower ratings were reported. 30-40 years ago HP ratings from the manufacturer were Gross HP ratings. Now everyone uses Net HP ratings. So that 1970 Chevelle SS with the LS6 454 that was rated at 450hp in 1970 would be rated closer to 375hp by todays standards. Net HP ratings have been the standard for at least over 25 years and maybe longer.
            • jjackkrash
              • May 2007
              • 498
              • PacNW
              • 2021 Ski
              Its interesting, the reports on ball of spray are that the H5 is a direct replacement for the 6.0l, and might be snappier out of the hole, with a little less top end. It sure does not seem to have much more HP than the 5.7; I guess it has a better torque curve.
              • FunkyBunch
                • Apr 2012
                • 40
                • United States
                • 2016 G21
                Have the H5 in my G21 IMO it is a great motor. I have not had any issues this year with and it gets the boat on plane fully loaded with no issue. I tested a G21 with the H6 and there is a noticeable difference in the 2. I went with the H5 anyway as I did not think I needed the extra speed. The H5 was a considerable amount faster to plane fully loaded and gets better fuel economy than my previous boat so I am perfectly happy. My understanding is the motor has more torque than the outgoing 6.0 even though the HP is down.
                If I was looking at the G23 I would not get the H5 because of the extra weight of the boat and additional ballast I would run in that boat. The resale of G23 with an H5 would also be more of a concern in that boat.
                • Miljack
                  • Dec 2004
                  • 1616
                  • Charlotte, NC
                  • '08 230 TE ZR6
                  Good posts on the new DI engines! This subject is very interesting to me due to the improved tech going into the new marine engines. After going from a Python engine equipped boat and believing that I would never be happy with a small block variant, I can say that our 230 with the LS 6.0 is a "better" engine. The LS has excellent torque out of the hole, runs very smoothly at all engine speed, and provides good fuel economy.
                  Given that the next development is direct injection, I can see why people are commenting on the "snap" and "torque" of these power plants. The "main" item here is the high static compression ratio allowed by the high efficiency of the DI system, which helps to alleviate detonation typically seen in "old tech" high compression engines. Think of it this way; the DI engines can run 11.0-1(+) compression ratios, this allows the engine to make low RPM power due to the (volumetric efficiency) efficiency of the combustion process. Think supercharger which introduces "forced induction" at low RPM's, the higher static compression ratio is achieving the same effect of the supercharger down low, and, has the added benefit of the increased fuel effficieny.
                  2008 230 TE-ZR6
                  • jjackkrash
                    • May 2007
                    • 498
                    • PacNW
                    • 2021 Ski
                    @Mlijack, I hope it rocks because I just bought one. Apparently the DI engines are also quieter. They sound like the bees knees.
                    • josemolino
                      • Feb 2011
                      • 235
                      • Barcelona Spain
                      • 2014 G21 2007 SAN 220
                      Hola,
                      Any thoughts on fuel consumption? I have a G21 with 6.0 409hp. Here in Europe, fuel consumption is an issue. (A Gallon may vary between $5 & 6,8)
                      I am considering to change to DI but there is no info regarding fuel consumption.
                      Regards,
                      • peter43
                        • Apr 2012
                        • 38
                        • Houston, TX
                        • 2004 SANTE 2016 G21
                        I have the H5 in my G21. I am really impressed with it. I was skeptical until I test drove one. Great hole shot when fully loaded. I have not maxed it out yet. Fuel economy is great too.
                        • jjackkrash
                          • May 2007
                          • 498
                          • PacNW
                          • 2021 Ski
                          Anyone know what the RPM redline is on the H5DI?
                          • jjackkrash
                            • May 2007
                            • 498
                            • PacNW
                            • 2021 Ski
                            Found the manual on here. 5600.
                            • jjackkrash
                              • May 2007
                              • 498
                              • PacNW
                              • 2021 Ski
                              Anyone know of any charts showing GPH fuel-burn rates at various cruising RPMs for this engine?
