Pic of boat rail system on forums?
  • Miljack
    • Dec 2004
    • 1616
    • Charlotte, NC
    • '08 230 TE ZR6
    Hey a while back someone posted a pic of his nautique, and had a picture of his railway system. I believe he was in the midwest?
    I did a search and can't find it, anyone know the author, or remember the subject?
    thanks,
    Jack
    2008 230 TE-ZR6
  • bkhallpass
    • 1407
    • Discovery Bay, CA
    RE: Pic of boat rail system on forums?
    It's Mark-S in the Classified Section, boats for sale. FS 2006 196.
    BKH
    http://www.planetnautique.com/index....ewtopic&t=5442
    2001 Super Air
    • Miljack
      • Dec 2004
      • 1616
      • Charlotte, NC
      • '08 230 TE ZR6
      BKH,
      thanks that was the pic I was looking for.
      Jack
      2008 230 TE-ZR6
      • Onthewater
        • 695
        • Near the cheddar curtain
        what the helk happened to my post with the same link? freaky board lately.
        http://www.planetnautique.com/index....ewtopic&t=5441
        unless it got deleted.
        I don\'t care.
        • bkhallpass
          • 1407
          • Discovery Bay, CA
          I thought that was odd. Seems like Miljacks post was entered twice. Whatever. BKH
          2001 Super Air
          • MARK-S
            • 764
            • SE MINN
            • 1978 Ski Tique 1996 196 2001, 2002, 2003, 2004,2005,2006,2007,2008 196s Best boats made
            Do a google on Hewitt boat lifts. Its called a roll-a-rail. If you have a gradual slope on you shoreline, its the way to go. In the fall prior to freeze up, I just take out 4 bolts and drag the rail out of the water.
            Life long Nautique guy
            Will ski anytime.
            \"SON WATERSPORTS ROCKS\"
            • Prairiedawg
              • Jan 2013
              • 61
              • Saskatchewan
              • 2008 Super Air Nautique Team Edition, 'Rider Green and White!
              Anyone else have marine railways to get your boat onto the shore or into a boathouse? I am currently building one and am planning on winching in and out of the boathouse to avoid having to build a sloped track in my boathouse. When I poured the concrete for my boathouse floor I cast two 2x4's in to allow me to remove them and add 3" channel iron for my track and not tripping over it all the time. I have since decided to use 4" channel iron for the track, so it will stick out of my floor a bit. I built my legs so that I can adjust each one separately, and fine tune the top of the track to keep it level all of the time. My track is built and almost complete, now I have to get the wood inserts out of my floor which is proving to be difficult, then finish my cart and mount the winch. If anyone has a winch that also winches the boat out I would like to hear about it! This pic is of one of the legs in primer.
              • GCSuper
                • Jan 2010
                • 292
                • North Texas
                • 2011 Super Air 210 2015 Super Air 210 on order
                There's a bunch of rail systems on our lake. They're grandfathered in, so no new ones can be built, but the old ones can be rebuilt and used. We're always seeing a boat in a difficult situation due to the rusting of the metal underground. If I were to build one, I would go the extra mile to seal the metal as much as possible.
                • Prairiedawg
                  • Jan 2013
                  • 61
                  • Saskatchewan
                  Thanks, do people leave them in all winter or take some or all of the sections out?
                  • 196 die hard
                    • Aug 2012
                    • 59
                    • Pine Island
                    • 96 196 2001-2009 196 Promo Rep for the years 2001-2009
                    I leave mine in all winter but it is above ground and not built in to any concrete pad. I live on a man made lake and dont have any ice flow issues to worry about in the spring.
                    • GCSuper
                      • Jan 2010
                      • 292
                      • North Texas
                      We're in Texas so they stay in the water permanently. Water is salty/brackish from the salt fork of the Brazos and is tough on metal of any kind. Probably why the BRA banned any more from being constructed.
                      • JDK
                        • Sep 2011
                        • 5
                        • Saskatchewan
                        I disconnect mine at the shore line -- then pull the 'dry section' and cart up the shore a little ways. Then I pull the submerged section deeper - and away from where there's any possibility of ice damage.
                        That's a tall stand -- how much elevation difference between your garage and the lake surface?
                        • Prairiedawg
                          • Jan 2013
                          • 61
                          • Saskatchewan
                          The boathouse slab is 2' thick, water level varies, I'm going with 50' of track, it gets me into water about 4' minimum on a low level year. My legs are adjustable for settling into the bottom, but the leg lengths are 48", 39", 27", 20" ( I think, going from memory). 4" channel for track, then 2" inside of 2.5" square tubing for the legs with 1" angle for the cross pieces. Should be strong enough. I see one guys system uses what looks like 5/8" sucker rod for legs and claims it is good for a 4000# boat......
                          • Prairiedawg
                            • Jan 2013
                            • 61
                            • Saskatchewan
                            Finally got the track fixed in the boathouse floor on the weekend.
                            • 196 die hard
                              • Aug 2012
                              • 59
                              • Pine Island
                              Looks awesome.
