Ye' ole boat lift question?
  • aaronmt
    • Jan 2016
    • 53
    • Washington
    • 2006 SAN 220 TEAM
    Were going to buying a lift and canopy very shortly.The boats a 220 and we will be getting roughly a 7k lift.The question is what do people prefer galvanized or aluminum.We are on a fresh water lake so corrosion really won't be that much of issue if at all.I'm leaning towards the Basta in galvanized,to me it's just seems far more substantial.What are others thoughts?
    Sent from my XT1254 using PLT Nautique mobile app
  • SANonTellico
    • Aug 2014
    • 301
    • Tellico Lake, TN
    • 2022 GS22
    I haven't paid close attention but I believe a vast majority of the boat lifts in Michigan are aluminum. One of the main differences is that the aluminum lift is much lighter, roughly half the weight. That's a huge benefit when having to take the lift out of the water every winter before the lake freezes then back in the water in the spring. Not sure how cold your winters get but if your not taking out the lift every winter then the weight difference may not be an issue for you.
    Previously: 2015 SAN 210
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      Yep, depends on where you are. Here in NC we don't really have trouble with the lakes freezing so the vast majority of the lifts are galvanized.
      -Charles
      • aaronmt
        • Jan 2016
        • 53
        • Washington
        • 2006 SAN 220 TEAM
        What are people's thoughts on the sunstream float lift
        • scottb7
          • Aug 2011
          • 2198
          • Carson City, Nevada
          Is there any benefit to galvanized over aluminum of the same capacity rating?
          • aaronmt
            • Jan 2016
            • 53
            • Washington
            • 2006 SAN 220 TEAM
            I believe there is a 300lb difference the steel being 7,000lb and the aluminum being 6700lb.They did mention that aluminum would be more likely to break if overloaded.Where as the galvanized would more then likely just not go up.I wouldn't be taking it and out during winter, everyone leaves them in year round.
