Possible new Nautique owner, need HELP!!!
  • thtrog
    • Apr 2012
    • 112
    • Asheboro, NC
    • 2014 G23 450
    #46
    Sean,
    I'm curious if any of your demos were from behind the boat? As a former Malibu owner I can tell you the stock G wave may not look as big, but the push is unreal!
    • Bottlefedsi
      • Jul 2015
      • 245
      • Clermont, Florida
      • 2023 G23 2022 G23 2021 G23 2019 G23 2018 G23
      #47
      My demos were all from behind the boat, the conditions weren't great and the wind was crazy so it could have affected the G21 demo but the 23 wasn't great either compared to the MXZ wave. I'm hoping the G can get better with more weight as the boat is far superior to the Malibu.
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        #48
        I can tell you the Malibu surfgate wave is huge at 10-11mph.
        i want to surf at 11.5- 12. The G23 is A+ at those speeds.
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2011 Malibu Wakesetter 247
        2007 Yamaha AR210
        • csherbo
          • Jul 2016
          • 10
          • Austin, Tx
          #49
          I'm curious about your comment about wanting to surf at 11.5-12. How come? I get adjusting the speed to get the right wave, but do you feel there is an advantage to your surfing at that speed?
          • nyryan2001
            • Mar 2013
            • 1993
            • Lake Anna
            #50
            For larger guys over 200lbs it's all about water pressure under the board. Increased speed = increased water pressure = more freedom up and down and away from the wave. A slow 1.5 wave has a 1-2ft sweet spot. Venture out of it and you'll lose the wave.
            2019 G23 450
            2014 G23 550
            2013 G23 450
            2007 Yamaha AR210
            • csherbo
              • Jul 2016
              • 10
              • Austin, Tx
              #51
              Thank you for that. That explanation makes sense.
              • nyryan2001
                • Mar 2013
                • 1993
                • Lake Anna
                #52
                Sorry... a slow 10.5mph wave looks huge and tall... but it'll have a tiny rideable spot for a heavier guy.
                get a knee high 11.5-12mph x 10ft long wave? The entire length will be rideable for a 250lb guy.
                most of the wakesurf pros are 130-170lb 20-25yr dudes. There's a reason for that.
                2019 G23 450
                2014 G23 550
                2013 G23 450
                2007 Yamaha AR210
                • Johnny_Rock
                  • Dec 2016
                  • 216
                  • MN
                  • 2021 G23 (Previously 2016 G23)
                  #53
                  How do I set up my 2016 G23 to get this wave?
                  • nyryan2001
                    • Mar 2013
                    • 1993
                    • Lake Anna
                    #54
                    Full OEM 2850 ballast.
                    11.6 to 11.8mph
                    +1100lbs in the surfside trunk
                    +500lbs in the other trunk.
                    +300lbs+ in the bow
                    NCRS 3-4 -play with this
                    surf vert 2-4-- play with this
                    most folks sitting surf side-- play with this, perhaps also in the bow
                    2019 G23 450
                    2014 G23 550
                    2013 G23 450
                    2007 Yamaha AR210
                    • Johnny_Rock
                      • Dec 2016
                      • 216
                      • MN
                      #55
                      11.6 to 11.8mph
                      +300lbs+ in the bow
                      So:
                      Add from stock: +1100lbs in the surf side trunk
                      Add from stock: +500lbs in the other trunk.
                      Add from stock: +300lbs+ in the bow
                      (How best to accomplish above? (Exact brands, means, methods, etc.)
                      NCRS 3-4 -play with this [Their setting is 5--which is zero adjustment down on this wave plate--dial down to 3 or 4?]
                      surf vert 2-4-- play with this: Now called NSS on 2016 and their setting is 0--which has the non-surf side tabs fully retracted or 'neutral' position; you're saying play with sticking it out to 2-4; 5 being all the way out.
                      Do I have it right?
                      Thanks...
