Question about Pebble / NSS | Pebble gone out of business
  • wakemaker
    • Aug 2010
    • 237
    #31
    http://www.planetnautique.com/Correc...eDowngrade.pdf
    this worked for me 2017 230
    • charlesml3
      • Jan 2008
      • 2456
      • Lake Gaston, NC
      • 2022 G23
      #32
      Originally posted by wakemaker View Post
      You should not have to downgrade the firmware on a 2017 230. Mine is running the latest firmware and works fine.
      -Charles
      • wakemaker
        • Aug 2010
        • 237
        #33
        thanks i will try it
        • tomsmith
          • Oct 2016
          • 35
          • north dakota
          #34
          i have a 2017 gs20 with linc 3.0 panoray. when i tried to install the nautique app on the pebble classic i bought new ( the watch or the app) made me update the software to v3.12.3. when i tried to sync the pebble with the boat it gave me and error saying to make sure the watch was not paired with another device. from what i can tell i unpaired it with my iphone 7 and tried a few more times then gave up. any advice if the version of firmware is wrong or any other input would be great
          • tomsmith
            • Oct 2016
            • 35
            • north dakota
            #35
            i also forgot to mention that after trying to pair the pebble with boat i thought i would try to pair it again to my iphone 7 and it would not work until i went into bluetooth and forgot the LE pairing that i guess is new to the later software?
            • charlesml3
              • Jan 2008
              • 2456
              • Lake Gaston, NC
              • 2022 G23
              #36
              The "LE" is the low energy pairing. I just looked and my Pebble is still paired with my iPhone even though I don't use it for that. You might want to reset the Pebble back to factory settings and start over.
              -Charles
              • tomsmith
                • Oct 2016
                • 35
                • north dakota
                #37
                thanks i see that the surf select 2.0 says it is compatible with pebble "time" watch and I have the pebble "classic" - does that matter and which watch do you have? thanks
                • charlesml3
                  • Jan 2008
                  • 2456
                  • Lake Gaston, NC
                  • 2022 G23
                  #38
                  I have the Classic. Actually I bought 3 of them off of eBay figuring at least one would get dropped in the lake at some point.
                  • tomsmith
                    • Oct 2016
                    • 35
                    • north dakota
                    #39
                    thanks what firmware version are you running? when i tried to use what came on the watch i could not get the app to install.
                    • charlesml3
                      • Jan 2008
                      • 2456
                      • Lake Gaston, NC
                      • 2022 G23
                      #40
                      I have the Pebble Classic with firmware v 3.12.3. The hardware is V3R3.
                      • tomsmith
                        • Oct 2016
                        • 35
                        • north dakota
                        #41
                        thanks again- does your watch show the ballast shift as an option? mine does not
                        • GMLIII
                          • May 2013
                          • 2798
                          #42
                          Yes mine shows a ballast shift option . Like Charlesml3, I purchased 3 of them (2) Pebble Time and (1) Classic becuase I figures some would end up on the bottom of the lake. Both of my models have Ballast Shift Option.
                          • tomsmith
                            • Oct 2016
                            • 35
                            • north dakota
                            #43
                            does it show the ballast shift option before it is paired with the boat? trying to figure out if the watch is the issue since it doesnt show that now and it wont pair
                            • GMLIII
                              • May 2013
                              • 2798
                              #44
                              Yes it shows the ballast shift before it pairs. I had issues pairing the watch with boat at first. First I paired watch with my phone and uploaded the Nautique Surf Select/Pebble info into the watch. All done away from the boat. I then went to the boat along with my cell phone and forgot all Pebble Watch bluetooth connections on my phone then I turned off the bluetooth on my phone altogether. I then went to the system settings on the touch screen on the boat to pair the watch with the boat. Now that the watch is paired to the boat , I never remove the watch from the boat . Once paired never unpair because it is a huge pain to re-pair. My bluetooth is soley used for the Pebble Watch and I use the aux cable to run any music; never bluetooth with cell phone or audio devices because it fights the bluetooth on the Pebble Watch if that makes sense.
                              • tomsmith
                                • Oct 2016
                                • 35
                                • north dakota
                                #45
                                thank you -yes that makes sense. i guess i will have to start over- where did you get the app? maybe that is my problem i got it at apps.getpebble.com
