03 216 - Use factory switches for ballast?
  • jhiestand
    • 778
    • Columbus, Ohio
    • 08 Super Air 210
    A bud of mine just picked up an 03 216 and would love to utilize the stock switches for a ballast system. I haven't looked at yet, but apparently it has 3 of the stock switches for the ballast system. I assume from other threads they can still be used -- anyone have direct experience in this area?
    I've seen that newer CC's use the membrane switches and they are two-position. One push is to fill, two pushes to empty. Would we be dealing with that type of switch?
    Thanks in advance!
    '08 Super Air Nautique 210
  • Quinner
    • 2246
    • Correct Crafts
    My 05' 206 works this way:
    1 push to fill - switch light turns on,
    push and hold then release to empty - switch light blinks.
    The 206 has 3 switches for ballast however only 1 tank so the other 2 ballast switches were wired to switch on/off tower lights.
    • porkchop
      • May 2006
      • 10
      • Ohio
      I'm the bud with the '03 216. I found all four sets of wires for the rear ballast. Don't think I'm going to be able to run reversible pump, but that's fine.
      I cannot find any wires for the Belly ballast pumps? Anybody know where those are hidden?
