I did it about 5 yrs ago. There is a thread on here somewhere about it. I just fabricated 2 plates and put a low profile swivel in between them and bolted it to the tracks under the seat. Worked just fine. Here's the problem. There isn't enough room between the seat and the throttle to swivel around, so you would need to off set it towards the middle of the boat which will take some figuring and more fabricating but could be done. Once you do it, the seat will no longer be centered over the base, which in my opinion will look goofy. I left it on there for about 1 trip out on the lake and took it off. Let me know if you figure something out that works good and looks good.
