Calling all Ballast Experts. 2004 SV211 upgrade question
  • WaterWeenie
    • Nov 2012
    • 17
    • Alexandria, MN.
    I am in the process of upgrading my ballast. I have removed the hard tanks. I really need to know what is the largest Sac I can fit in the rear port locker. I have searched and found conflicting answers. I am going to put the same size on both sides. I am ready to order whatever I need and just want to make sure I get it right. Any advice for the floor ski locker would be great too.
  • markj
    • 1194
    • NorCal
    Measure your compartments and have wakemakers build some custom sacks for you. It doesn't cost that much extra to go custom and then you get maximum fill/weight.
    • rocket88
      • Jul 2012
      • 14
      • Brandon, MS
      • 2005 SV 211
      I'm in the same boat as you... I have my hard tanks removed and I'm trying to figure out what bags to order. The tankbuster kit from Wakemakers comes with a 750lb bag and a 400lb bag for the walk thru side. I think a 600lb bag would fit in that spot but would like to know for sure before I pull the trigger.
      • WaterWeenie
        • Nov 2012
        • 17
        • Alexandria, MN.
        That's exactly my thoughts! I want it to be evenly weighted....
        • ski4evr
          • May 2010
          • 613
          • Bowling Green, KY
          • 2005 SV 211
          You can put a 750 port and a 400 stbd. Not sure if a 600 would fit stbd, would probably pop walkthrough up. Can put the 260 on top of walkthrough. No room for anything in compartments at all when bags are full. got skiis in my center locker, but a 260 fits in the walkway. the 260's come as a set called side sacs. the underseat bag for the front is almost a waste, not enough room under cushions, a 400 fits up front in the seats. The 370 lb tube sac fits under stbd passenger seats, again no storage left. I figured out if I want all the board time, I don't need storage, just a driver. If I fill the boat with people, don't need as much ballast, just more storage.
          2005 SV-211
          • MikeC
            • Apr 2007
            • 535
            • Georgia
            • 1999 Ski Nautique (Python powered) 2017 GS22 (sold) 2005 SV211 (sold)
            I removed the rear hard tanks and put 750's in each side. The port side wouldn't fill completely but it's unnoticeable, and it's better than having that much smaller bag.
            • dixxy
              • Apr 2015
              • 136
              • canada
              • 2019 GS22, previous boat 2005 SV211
              Dito with MikeC
              I have the exact same boat and this is the setup that i have..it's pretty amazing how much port side will fill up. ..
              Mine the pumps got changed as well. .if you need more info let me know I'll be glad to provide more and send you pics of the setup...
              Good luck
              Sent from my SM-G900W8 using PLT Nautique mobile app
              • theskunk
                • Oct 2014
                • 232
                • Stafford, VA
                • 2006 sv-211
                Final recommendation - pick up a set of the wake makers engine panel savers - when you start filling up the bags, especially the starboard side, they will start to bow, even with custom ones!
